Folks can someone help please,
I think 255/45R18 with 30 offset and 3/4: spacer works well in the front, please correct me if I'm wrong..
but for the back I'm perplexed....anyone running a 285?295?305? if so what is your setup?
If they are the same fenders & brackets as the hot rod, 255/35ZR18 fit but needed 1/2" spacers to center on 18"x9.0" wheels with 5.0" back spacing.
BTW, the wheel width is important for these wide rear tires. If I ran a narrower rear wheel, the vertical sidewalls would reduce fender clearance.
Thank you that's exactly what I hope to run, thankyou for the reply.. Cheers
