Page 12 of 12 FirstFirst ... 2101112
Results 441 to 470 of 470
Thread: Factory Five GTM Supercar, fastthings video build log
  1. #441
    Well, I hope to continue my good record of 0 tickets.
    I don't know if I told you guys, but I have my plates now. I need to get some insurance, then I will take it out for some shake down runs.
    Do you guys remember hearing the whistle from my front grill, in that last video. I have to do something about that, I wonder what that may be?? Any suggestions?
  2. #442
    Catonsville, Maryland
    Gene,
    Reach out to RumRunner.
    He had Shane's front grill, and it whistled at certain speeds. He did a modification that stopped it, not sure exactly what he did, but it's not too involved if I remember correctly.
    Ron
  3. #443
    I thank you Ron.
  4. #444
    Gene I just came across this post http://thefactoryfiveforum.com/showt...ight=GTM+grill
    Hope it helps
    Ron
  5. #445
    Senior Member Edgeman's Avatar
    Medicine Hat, Alberta Canada
    I have Shane's front grill and have not experience this whistle. I put it together with panel bonding, only on the bottom side. Then painted it with black spray paint. Put the thing in straight and that was it. I see you put in a camera and cut the fins. Mike also had done that, so I am not to sure if that has something to do with the whistle.
    GTM #370
    Car was completed and I have SOLD my car
    http://edgemansgtm.weebly.com/index.html
    Doing what you like is freedom - liking what you do is happiness
    later,
    Doug
  6. #446
    thanks guys
  7. #447
    Hey guys, I am having trouble calibrating my fuel and speedo gage, most likely two different issues. I'm more concerned about the fuel, I have ran out a couple times.
    I get a floating needle, it did that right from the start. I have calibrated the empty and full points. Read the directions and watched Speed Huts video.
    I check ohms behind the gage at empty, 226. I fill the tanks and still get 226. I check at the sender and get 226. I can ground to the frame and still 226.
    Is my sender bad?
    What so you guys think.
    The speedo wonders around also, I have calibrated it 3 times. Maybe my sender is to far away and not completely centered. Is it that critical?
  8. #448
    LCD Gauges's Avatar
    Toronto, Ontario
    You are probably measuring the wrong two wires on the sender. You need to find the "wiper" wire of the sender which indicates the float pisition.
    It seems like you are measuring the two wires that span the entire resistor.
  9. #449
    Interesting, I thought I checked different combos, I'll check again.
    I have 3 posts, I can't see the top to read. I have one wire in the middle, and one to the left.
    And I have the aluminum tanks.
    Any suggestions?
    I was hoping you would chime in,
  10. #450
    LCD Gauges's Avatar
    Toronto, Ontario
    This is similar to your float wiring. You need to find the middle wire that moves with the float.
  11. #451
    thanks I'll check it out. I hope the sender is not bound up from shipping and that. I guess I should have checked before the install.
  12. #452
    Ron's tanks calls to have 12v power connected. I am sure you did that. Tino it has a different style of a sender in it than you posted, not sure if it acts the same way.
    GTM #370
    later,
    Doug
  13. #453
    Sender is rated 15 to 160 ohms, the post on the left is labeled sender-white wire. Center post labeled ground-black wire. Right post labeled positive -empty.
    the only combo I can get a reading on.
    it reads 226, over the rated specs.
    not sure what to think, bad sender ?
  14. #454
    You have 12v power connected to the right one? I had the same problem untill I connected the 12 power to it, would not read on the gauge.
    GTM #370
    later,
    Doug
  15. #455
    Quote Originally Posted by Edgeman View Post
    Your shi*in me, I was wondering. But then I pictured powering it up, and causing a spark, and watching the whole thing go up.
    Thank you, can't wait to try it.
    Any thoughts on the speedo?
  16. #456
    I have a working fuel gage now. Thanks Doug, it's amazing how such a little thing can ruin a ride.
    I'm using my tab app for a speedo, but would love to get the gage to work. Time to focus on that.
    One more thing, went to charge the AC. The connection to the top of the canister, that sits by the battery. I must have the wrong gasket. I have the green oring, and it's very loose.
    Any thoughts.
  17. #457
    What's up guys. I have been so busy this summer. I still read this forum. the other seems to have too many virus.
    I have been to a few shows out having fun.
    https://youtu.be/OkzC7_xO2t4
    Here is a walk around I did.
    https://youtu.be/I_67-mLUMcc
    This is my local town car show.
    https://youtu.be/IB9R8rmiJtY
  18. #458
    Charlotte, NC
    Beautiful! You really did a great job Gene. You car just looks outstanding!
    The Stig
    GTM #0081
  19. #459
    LCD Gauges's Avatar
    Toronto, Ontario
    Congrats on winning best exotic!
    Tell me, how did you get all of those young girls to sit on your car?
    Where you handing out candy?!
  20. #460
    Thanks guys, they all like the GTM. I have been to a few different crowds, it is well liked.
    Those girls are nice for doing that, lots of fun.
  21. #461
    Senior Member Taz Rules's Avatar
    Dec 2012
    BC, Canada
    Gene
    I sent you a PM
    It would be a trajedy if your car wasn't in this year's calendar.
    Just sayin.
  22. #462
    Umm ...wow .....I'm definitely building a GTM now. LOL
  23. #463
    Quote Originally Posted by Taz Rules View Post
    Gene
    I sent you a PM
    Just sayin.
    Hello,
    I have been off the grid, I have been so damn busy.
    Can you believe I still have not taken any pics yet. Lots I have not done yet.
    I wish I had some pics for you, sorry. I do want in, most likely next year.
    Thanks again
  24. #464
    Quote Originally Posted by Aceflo View Post
    LOL,
  25. #465
    Here is an update of sorts, I love it.
    What a frickin blast. I have minor things to redo, but all in all, good to go.
    One thing, Mendeola currently has my box. It is popping out of third, life in the fast lane, they'll fix it.
  26. #466
    Oct 2014
    Southern Pines, NC
    Gene, well I watched all your videos in a weekend and that's what got the fever going, now that I have a GTM in my garage I'll have to re-watch them. I'm actually excited to watch them again, hopefully I'll pick up even more info now that I'm a little more informed. Thanks again for taking the time to make those videos and post them, and that thank you goes to all the build logs out there, I've read them all lol
  27. #467
    Quote Originally Posted by tucker298 View Post
    My pleasure, if you watched them all, you heard me many times give thanks to the guys on the forum. I can imagine the insight you would have going into a build after watching, cool stuff. This forum has almost got this build refined, good bunch of builders.
    I like it that I get people riled up, good luck on the build.
  28. #468
    May 2021
    Hi Gene,I have just joined the forum ,your build is amazing hope i can build mine somewhere close to your GTM.I have a question re your wing mounting to the frame/chassis Did you make the hardware or can you buy these mountings? Thanks Aussie Mike.
  29. #469
    Hi Aussie Mike. The mounting system he has appears to be ours....
    http://vraptorspeedworks.com/vrsw-ne...-mount-system/
    Shane Vacek
    www.vraptorspeedworks.com
  30. #470
    May 2021
    Thank You Shane.
