You are just removing the grease so it does not run out and cook when they are in the powder coating oven. I just used a can of brake clean to flush the grease out of mine. Spray, move ball joint around, repeat, repeat, repeat until cleaned out. Ask your powdercoater to mask it off to keep sand out of the joint when they clean/sandblast it.
