murdunjam
Hi. Looking for ideas on how to cover the holes across the back and side of the hard top inside ( holes that give you access to bolts holding top down ) . Also would like to hear from someone who has installed power brake booster unit. ( booster size and installation problems if any). Thanks
I was planning on doing what wrp (Bill Price) did, he made a leather trim piece similar to what is used to finish off that area when the hard top isn't on (roadster mode). Will add velcro to hold it in place. You can see Bill's in one of his videos, check out post 763 of his build thread
https://thefactoryfiveforum.com/show...Restart/page20
Gen 1 '33 Hot Rod #1104
power brake booster in a Hot Rod / Truck
The answer for power brake booster depends on which engine and body configuration you have - space under the hood / inside the side covers is very limited. If you are running without a hood or side covers you have more options. If you have a physically small engine, the easiest choice is the Whitby power brake system https://www.whitbymotorcars.com/prod...-kit-complete/ . I suggest you call Jeff Collins at (336) 389-0904 to verify that his system will fit. Whitby has apparently installed the system in several Hot Rods with SBC, SBF or LS engines.
I am running a Coyote engine though, and the Whitby booster is too big in diameter to fit. I bought a booster/MC assembly from Summit that has a 7" dia. booster and am currently trying to shoehorn it into the Hot Rod. The pumpkin fits fine, but the MC is a full size GM style unit with built-in reservoirs and the brake lines interfere with the engine side covers. I had fab some mounting tabs and tilt it a little to fit properly. I also had to fab a bell-crank type assembly to convert the pedal motion to the correct stroke. Of course, you avoid all these issues if you can make the Whitby system work in your vehicle.
HTH, Keith HR #894
Originally Posted by
progmgr1
HTH, Keith HR #894
I installed the Whitby system in my 33 a couple years ago and I really like it. I did it after the fact so I had to contend with wiring and AC venting in the way but that got worked out. I ended up removing the Wilwood pedal bracket completely and cut off the mounting studs where the Wilwood cylinder sat. Just for more room with less stuff to scrape my hands on. The Whitby system uses a normal 7" booster along with a "corvette" style MC and Whitby's custom made brake pedal and linkage. You'll need to redo your brake lines but it is overall a fairly simple install job. My side covers fit just fine with this setup. Just remember to make you lines from the MC bend as sharp as possible if coming out the drivers side. I plan to replace the lines I made up with banjo fittings and -3an braided lines to a junction block down on the frame. I also used a banjo fitting with brake light switch to eliminate that crappy pedal activated FFR switch that is impossible to adjust. Good luck..
progmgr1
HTH, Keith HR #894
Hi. Thanks for the info. I will call Jeff at Whitby Motors. I'm running a 306 Mustang engine with hood but no side covers so I might just have enough room for it to fit. Thanks again.
Brave Salmon
Hi. Thanks for the info.Seems like theWhitby Motors unit is the one to go with. I'm not running side covers so that should eliminate some of the problems . Does Whitby supply a brake pedal and linkage.
FF33rod
Hi Steve. Thanks for the info. The trim piece looks good.
Here are a few close up shots. I pulled it off the velcro to show the holes and just slapped it back to show the strip in place.
Seq-17g3.jpgSeq-17g4.jpgSeq-17g5.jpgSeq-17g6.jpgSeq-17f9.jpgIMG_7845.jpgIMG_7846.jpegIMG_7847.jpeg
wrp
Thanks, pic's make it easier to see what you did.
Also cuts down on wind noise and stuff coming through from the trunk via the shoulder belt loops
wrp
Ok. Thanks
