0
0
Alt / starter harness firewall hole location?
Hi all, I have been studying a lot of build threads and do not commonly see the suggested FFR location used for the alt/starter branch of the chassis harness. But I can't tell where/how people are routing this branch. Suggestions?? Pics would be very helpful. Thanks in advance!
Here's the suggested location:
Matt
FFR Complete Kit, Coyote, Tremec TKX, 3.73 IRS, power steering, 18" Halibrands, Wilwood brakes, Gas-N pipes + header, Viking blue color
Roadster Build Time Tracker
Go into FF5 site and look for instructions for all the different models- you’ll find most of the instructions for just about everything. Ron Francis also has the instructions for their FF5 kit. I recently found an early version dated 2012 which was a little different. The holes in your photo are to the right of the center support bracket. But you should see a page showing where you place the holes to run different wire bundles. I’m sure everyone does it a bit different. For example when we started to mount the vintage air ac compressor, we couldn’t get the drive belt to line up with our setup. We ended up using a different mounting system.
Mac morgan
Originally Posted by
JohnMac
Mac morgan
Thanks Mac, appreciate the perspective.
Matt
- You may not post replies
- You may not edit your posts
Forum Rules
