0
Originally Posted by
Ajzride
You should be able to test the lights themselves with a 12V power supply from a router or RC Car charger or something like that.
Thanks. I should have been specific. Eventually I'll understand that just because it's in my head doesn't make it obvious, and it definitely wasn't here. I'm more concerned about my wiring than the cluster. I think I remember the lights working before I tore the wire harness apart, but now I'm not 100% positive because it was so long ago, so it looks like I'll be trying this anyway. Good tip, and I have probably a half-dozen of those things laying around. Thanks again.
Kiwi Dave
My 07 WRX donor cluster lights work when I turn on the headlights switch with no other lights hooked up.
Uh oh....
