The way I understand the switch is that it detects the increase in pressure in the brake line as you step on the brake, at which time it closes the circuit and the brake lights light up. The switch is directly wired to the brake lights just as you would wire the switch behind the brake pedal. Eliminates the need for the little switch behind the wilwood pedal. It is not meant to measure or monitor the line pressure per say.
