30
137
I have been drilling holes for days in the right side of the front firewall, side intrusion panels, and the rear engine-side firewall. I am on my 3rd drill bit and already running low on the 1/8" rivets so I will have to get more eventually. I am still up in the air if I want to make my own internal side pieces like Justin shows in his last picture or eliminate them like others have done.
I finished the rear engine-side firewall in 3 pieces and added a layer of Thermo-Tec aluminum heat shield and quickly noticed my lines were a bit off, but it still looks pretty good. I will seal the lower 2 panels with some silicone on the cockpit side. I have the rear suspension hung and have started on the front. I can only work on the front right since I am still waiting for the special sheetmetal pieces for the Wilwood pedals. I am a bit confused the R instructions doesn't specify what type of bolt is used on the rear bushing on the front LCA. Is this supposed to be a 1/2" or 5/8" bolt? The washer stack it says to use are 5/8, but in the pictures it looks like a 1/2" bolt. The holes in the frame tabs are ~0.58" so it does not seem like a 5/8" bolt is supposed to go there, but I want to ask to make sure. I have it mocked up right now with 1/2" bolts from the supplied hardware, but they seem too long so I might buy a shorter bolt if it is supposed to be 1/2.
I also had to switch the rear bushings on the front LCAs to make sure they aligned with the frame left/right tabs. This meant I had to undo the 184 ft-lb nuts. Now that the front firewall is in there I need to retorque this nut before I install the LCA. Do these rubber bushing need any grease (small amount of lithium/chassis grease)? The FSM does not say to add any, but they seemed really tight when they were torqued because I could not move them. Just curious if it would help or if that is a no no.
blomb11
Believe it or not it's Metric for the OEM size donor bolt!
IMHO switch all the crappy FF supplied bolts for AN bolts and OEM suspension bolts.
See my build thread starting at Post #344.
https://thefactoryfiveforum.com/show...l=1#post458587
Owner: Colonel Red Racing
eBAy Store:
http://stores.ebay.com/colonelredracing
818R ICSCC SPM
