Results 1 to 6 of 6
Thread: IRS rear brakes 11.65
    Nov 2020
    I am having problems with the rear brake caliper mounting
    Everything looks lined up centered square
    But when you tighten caliper bolts it locks the wheel
    Loosen 1 of 4 mounting bolts and it frees the wheel
    What am I missing??
    Heart of Dixie, Alabama
    Caliper probably needs to be shimmed to center it over the rotor.
    Nov 2020
    Thank you railroad
    I have 1shim in each mounting
    I take them out and I can not get
    Caliper on
    Do you think I should try 2??
    Will need to fabricate washers
    Oh joy. Lol
    Make sure the pads are properly positioned in the caliper, not askew or in a bind.
    Push the pads to the most open position, by hand.
    Set the caliper over the rotor and try to center the pads over the rotor.
    If you can see where the caliper mounts against the brackets, estimate the gap. This should be a ball park thickness of the shim(s) you need. You can use steel washers, they do have different thickness available, to fill in this void.
    Your bracket mounting surface needs to be parallel to the rotor. Run a couple of lug nuts on the wheel lug bolts to hold the rotor in place and true, while working on this.
    When you get things bolted up, check to make sure both ends of the caliper are square with the rotor.
    ie, do not have one end closer to the rotor than the other.
    Nov 2020
    Cool. Thank you very much
    Wish me luck
    Nov 2020
    Thank you for your help
    I ended up with 2 shims on each side
    Also found pad hardware rubbing against rotor
    I’m good to go mags in thanks for your input
