Likes Likes:  14
Results 1 to 10 of 10
Thread: #20 comes to visit
    #20 comes to visit
    About a decade ago, good friend of mine‘s father-in-law bought hot rod number 20. Brand new, picked it up right from Factory Five and after the races they went. Like most of these projects I would imagine, they hit snags they couldn’t overcome and eventually gave up. But they did get the broad strokes done. Engine, trans, suspension brakes are all in place.... but the car doesn’t run, I don’t think it’s ever been driven and really need somebody to shove it over the finish line.
    I got a call a couple of months ago and found a hole in my schedule. Now it’s my problem. So, I take a 302, T5 car with a carburetor that’s as early as they get and make it into a car.
    interestingly, for the most part it looks like they did good work. They just need somebody to do the last 10%
    33 Hot Rod #1133. LS/TKO600
    Titled 2-28-20
    MkI.IV 2643k
  2. Likes RoadRacer, 33fromSD, shmelty liked this post
    Cool S/N
    Titled 2-28-20
    MkI.IV 2643k
  4. Likes wrp liked this post
  5. #3
    That can’t be good...
    Titled 2-28-20
    MkI.IV 2643k
  6. #4
    Sep 2019
    The question on everyone's mind is will #20 be painted before Seth's car?
    It will be cool to see the differences.
    Andy
    33 Hot Rod with Deluxe Grill (32) Hood & sides, Bike Fenders, Hard Top, AC, Power Windows, Electric Power Steering, 306 Ford Small Block - roller cam, aluminum heads, Eldenbrock intake & carb, T5, Moser 3 link, Arrived 5/6/20.
  7. #5
    Funny, because it’s true. The answer is probably. The enjoyment I get out of my car rough might be reduced by spending a fortune on paint. I’ve bumped that car off the rev limiter it so many times and it worries me. It’s a donut king. And I can’t drive it without burnouts.
    Quote Originally Posted by e36m3 View Post
    Andy
    Titled 2-28-20
    MkI.IV 2643k
  8. Likes RoadRacer liked this post
  9. #6
    The engine failed the leak down test spectacularly. Hoping the rings are stuck. Little MMO and a month of soaking....
    Calipers on order; carb being rebuilt, rest of fuel system resolved...
    Titled 2-28-20
    MkI.IV 2643k
  10. #7
    Carb.... don’t let ethanol sit............
    **** turns to glue.
    Titled 2-28-20
    MkI.IV 2643k
  11. #8
    New brakes, rebuilt the carb, buttoned up the fuel system, found a filler pipe that will work, required the car and am starting on fixing the awful bracket for the hydraulic clutch.
    Titled 2-28-20
    MkI.IV 2643k
  12. Likes FF33rod, David Hodgkins liked this post
  13. #9
    Machined a new Clutch slave bracket. Not sure if it’s too much angle,yet, but at least it’s not under the gas pedal.
    Titled 2-28-20
    MkI.IV 2643k
  14. Likes Blade liked this post
  15. #10
    Titled 2-28-20
    MkI.IV 2643k
  16. Likes CaptB, peterh226, FF33rod, HVACMAN, 33fromSD, e36m3 liked this post
