Thanks Thanks:  5
Results 1 to 8 of 8
Thread: How/ where are you guys mouting the rear fuse box?
    Question How/ where are you guys mouting the rear fuse box?
    Hello,
    I am hoping that you guys can give me some ideas for mounting the rear fuse box. I am using the original harness from a 2007 WRX, only a little dieting nothing serious (only the Air bag system). The manual makes a vague reference to mounting the box behind the driver's seat firewall. Their very elementary one line shows it in the engine compartment.
    I sure would appreciate some pictures on how you guys did this! I can't seem to find any in the Forum.
    Thanks!
    Sam Terry in beautiful northern New Mexico.....
    Apr 2021
  3. Thanks SamT01 thanked for this post
    Apr 2021
    https://thefactoryfiveforum.com/show...l=1#post444556
    This is a great set of pictures and discussion of wiring
  5. Thanks SamT01 thanked for this post
  6. #4
    Apr 2020
    I found that mounting the black fuse box at the front of the tunnel reduced the number of wires that needed to be lengthened. Mine looks like this.
  7. Thanks SamT01 thanked for this post
  8. #5
    Apr 2021
    RPGs818SNA I like your lacing job keeping the wiring together. I don't see that much any more.
  9. Thanks RPGs818SNA thanked for this post
  10. #6
    Senior Member octobersknight's Avatar
    I ended up putting mine up front. See https://thefactoryfiveforum.com/show...18-Build/page3 posts #104, #112, #114-115. As RPGs818SNA says, you will probably have to lengthen fewer wires this way, but I didn't figure out where to put it until after I lengthened everything anyway.
    818C chassis #546. Ordered 8/14/18, picked up 10/6/18. First start 01/16/2021!
    Donor: 2006 WRX wagon, 108k miles.
    Options: Chassis powder coat, CF street splitter, rockers, diffuser, and spoiler, polished shift knob, adjustable rear lower lateral control arms, vinyl padded dash/door, complete carpet set, battery cut-off switch, wiper kit, aluminum shifter assembly, complete CV axles, harness bar mount, matte gunmetal wheels.
  11. Thanks SamT01 thanked for this post
  12. #7
    Apr 2020
    I mounted my front fuse box (the one that was originally inside the car) under the dash right in the center. I mounted the main box in the front compartment, mostly because it kept me from having to stuff even more wire into the tunnel, and it will be more accessible there. I cut down the original black container and lid. I can't imagine locating it in the engine compartment, at the other end of the car, but that's what the manual says, but I think there are a lot of options based on the year of the donor. My donor is a '07 WRX also, so yours should be similar.
  13. #8
    Bolton, Ontario, Canada
    I mounted it behind the passenger seat with a 3D printed cover over it.
    Rick
