So one of the guys (Jeff Evans) on the FB group gave me an idea to make my own plugs using the inboard CV housing from the half shafts. He ended up cutting close to the CV joint and plugging the remaining stub back in the center section. I started cutting and then got lazy and took the boot off to see what that CV joint looked like. There is a thin lock ring just inside the lip of the housing. Once you remove it with a small slotted screwdriver that whole CV joint just comes right out. A little brake cleaner to clean the heavy grease out of it and I now have a set of plugs that fit perfectly.
