Results 1 to 9 of 9
Thread: 302/347 Headers for '35 Truck
    Mar 2021
    Bradenton, FL
    FFR tells me I need Shorty headers with 1-5/8 tube to heads and 3" pipe to 3 bolt collector. I would like to get ceramic coated or stainless. I can find lot's of headers at Speedway,Summit,Jegs, Amazon but none that fit the desription above.
    Anybode got a good source for this?
    Jun 2018
    North Vancouver, BC, Canada
    It should be the same as the hot rod and BBK 15150 worked perfect https://www.summitracing.com/parts/bbk-15150
    Gen 1 '33 Hot Rod #1104
    Fox body shorty headers work. BBK is a good choice.
    16+ FFR kits and counting!
    Mar 2021
    Bradenton, FL
    Thank you Steve.👍
    Mar 2021
    Bradenton, FL
    Thank you Wallace ��
    Mar 2021
    Bradenton, FL
    I need more help: Emailed my FFR Rep Mike on Tuesday asking about the header collector connection and emailed and zero response yet. Not Happy! ( Today is Friday) He told me its 3 bolt on the collector from FFR and the comments here points towards Headers with a 2 bolt connection. What am I missing? Should I specify a 2 bolt connection from FFR? 3 bolt shorty headers seem hard to find or very expensive.
    What to do?
    Aug 2018
    Hampshire, IL
    I have a SBF 347. And it’s a 2 bolt . I believe 2 is what your looking for. Hope others chime in and confirm what they have.
    Rob.
    Jun 2018
    There's a knowledge gap at FFR since Tony Z left. Add to that the very challenging supply issues all over the world.....
    it's 2 bolt, with a 2.5" collector. The BBK headers I mentioned above were recommended by Tony and work perfect. Sounds like you don't have your kit yet to be able to see first hand. As long as you specify (or have specified) "Installing Ford 289/302/351W Engine" on the order sheet you'll be good.
    Mar 2021
    Bradenton, FL
    Thanks Steve, finaly got it straightend out. And yes it is as you stated.
  10. Likes FF33rod liked this post
