The uca does affect bump steer. As the lca rises, it describes an arc larger than the arc followed by the uca. If the uca causes camber increase, and the lca does not follow(larger radius) the distance from the steering knuckle to the steering rack changes, thus causing bump steer. The trick is to position all three elements such that the distance between the steering rack and the knuckle remains constant throughout the travel.
