Not a waxer
JohnK
Wow - that's a great catch - thanks! No, that won't work. I need something that's accessory -fed. I'm going to use the heater circuit for the heated seats, so I may use the radio circuit for the e-brake.
Again, that will only be hot with the key on. Consider using the radio MEMORY wire which is energized all the time and is fused.
