Great videos! I'm looking forward to following along with your adventure. Welcome aboard!
Great choice on the LS engine. Pretty sure you probably know you’ll need to get the theft features removed from the ECU.
Have a great time with your build.
Remember to route your rear wiring harness before you permanently install your trunk floor pans.
Also, pre-drill your roll bar(s) prior to fitting the rear cockpit aluminum because it will really make that task a lot easier too.
Good Luck & Happy Riveting & Wrenching!
Make sure that you DON'T install the driver's side outside foot-box panels until after you've done some shakedown Go-Kart runs.
Leaving those off will make life a lot easier in the event that you find yourself needing to adjust things as your build progresses.
Good Luck & Happy Wrenching!
PS:..Your Son Is Super Cute Handy Helper & Will Be A Major Motorhead Forever!
Mathew, If you'd like to allow your videos to play directly here on the forum rather than opening a new window, reply and click on the "insert video" icon and then load your link.
Abracadabra.
__________________________
Fantastic, thanks!
Gonna leave the river. It secures that headlight switch better than the nut. Prevents the switch from rotating.
