0
0
Lower Radiator Mounts misaligned
Was working on my build, and got to installing the radiator, however the pins on the bottom of the radiator were too narrow to fit in the lower bushings/isolators. I was installing a Mishimoto, so I grabbed the OEM to check, and it too was too narrow. Pin center to pin center on both radiators is 52mm, but center to center on the mounting holes is 54mm. Am I missing something, or is it possible the mounts on my radiator support were misaligned? Thanks!
