0
0
Originally Posted by
Brad s
It’s a 35 truck with a six speed manual I’m not getting the frame powder coated simply because if I have to start doing some modifications it won’t be a problem
That’s gonna be sick! It’s a ton of work, but if you can’t find enough room for the LT4 accessory system, you could always remove the water pump and use a remote electric water pump and have someone custom build a much tighter set of accessories with supercharger pulleys.
Looking forward to seeing the progress.
