My 33 ford is on order. The trigger has been pulled!
Options
34575 - Powder coated chassis
33462 - Installing Ford 289/302/351W Engine
- Installing Automatic Transmission: (Default configuration)
34050 - 28 spline driveshaft for 302/351W/4.6L/5.0L Coyote with 2015 IRS and T5, AOD, or Tremec 3550 Transmission
16325 - Black Vinyl Roadster Seats
34058 - 2015 Mustang-based Independent Rear Suspension Kit with KONI coil-overs, tubular lower control arms, and CV axles
15945 - 2015-2017 Mustang IRS Manual Driveshaft Adapter
34838 - '33 Grill with Hood and Engine Side Covers
34090 - Hot Rod Spread Rear Exit Exhaust – Polished stainless with 2 oval tips, located under tail lights
33650 - Upgrade: Tilt Steering Column, Chrome Plated
34075 - Electric Power Assist Steering
Got a 2019 IRS with 16k for a great deal. So one part - check
Going to find a deal on an AOD and rebuild it myself.
Hopefully run into a deal on a long block, if anyone knows of one LMK.
Plenty of time to figure it all out with the long backups....
Thanks for all the advice in the forum that pushed me over the edge!
Post Thanks / Like - 0 Thanks, 4 Likes
