My dang torque wrench got stuck and I ended up shearing a hat to rotor bolt, Wilwood P/N 230-8008, 1/4-20x0.75 LG.
I only need the one! A full 12-piece kit from Wilwood will cost me nearly CAD$100.
32J
32J
I can’t help you with one bolt but you do realize that the torque spec is inch pounds, not foot pounds—-right?
Yes, had it set to 155 in-lb. I did the rear brakes just fine 4 weeks ago. My torque wrench jammed some how and didn't click. My fault for not paying attention. Worked fine on all the other bolts.
