Boomer Sooner!
Boomer Sooner!
Forte's Axle
Rah Oklahoma!
Didn't do so great this past weekend though...
IRS Center Section
Now to the actual build!
After we got back from Boston and I placed my order, the urge to do something was killing me. I originally ordered a new center section from FFR with my kit. After reading EdwardB's build thread (I think it was his 20th Anniversary Roadster - could've been his Coupe, can't remember), I caught that Ford Performance wasn't offering the Torsen 3.73 center section any more, and only a few still in stock at places. Since his thread was a little older, when I looked, they were wayyy long gone. Nothing wrong with the clutch style locking version Ford is offering, but it's a 3.55 ratio, and if you can find a Torsen, I'm told it's the way to go. Reading that the 3.73 ratio matches nicely with the T56 gears, I set off to find one. Good old eBay. Found one from a 2020 Shelby GT500 that had under 10K miles for $700. Too good a deal to pass on, so I ordered it. After $125 in shipping, I had it in 2 days. Can't beat that. So even after buying the rear knuckles and hubs from Summit Racing (the FFR option comes with those along with the center section), I'm under the $1499 that the 3.55 would cost me from FFR.
The unit was pretty nasty, which is to be expected coming from a parts farm out of a wrecked (presumably) car. I cracked it open to see what it looked like, and it sure looks like it's not got a lot of miles on it. The ring gear looks nearly new, and the pinion did as well. No chips, wear patterns, nothing. Even so, I planned to replace the bearings and seals just to be 100% sure. Tore it down pretty quickly, and after some time in the blast cabinet to get all the rust off the iron case, I painted it with a few coats of the POR top coat gloss black. Unit looks brand new.
Here's some pics of the process. First few are of the "walk around" after unboxing it, then a look at the ring & pinion gears. Last photo is the iron case after painting.
