Going slow when the temps are low...
When its warmer (30+) I'll heat up the garage and work a while. When its colder I'm in the basement cutting out body vents.
Got the FFR mono wiper installed. Not adjusted, gonna need a windshield for that. At least got the electrical handled.
Also working on trimming out the shifter and e-brake areas a little. Needs a bit more work, but getting there. I like the idea of covering this aluminum with wrap material. Hides a few hammer marks.
Still figuring out the shoulder harness anchoring. Thinking of a bolt-in bar across the whole width behind the rollbar legs, sitting on the square tubes back there. Puts it about the right height. The HANS device actually raises where the belts head thru the seat and so helps the angle a little.
I forgot to mention; I made a little boot for the ZBD shifter from a steering rack bellows. Is there a better solution?
Post Thanks / Like - 0 Thanks, 3 Likes
