Missing some Brake Components... Need help finding replacements
So I am finally working on my kit again, bought it back in 2015 and spent quite a bit of time tearing apart and rebuilding the Donor parts before 3 kids and two moves! I am routing my brake lines now and cant seem to find some components, missing the two TEE's, metric/standard thread adapters, as well as the couplers to join the hard lines...
I have found some options for the TEE's and couplers below. Was looking for some suggestions on which thread adapters I will need? I think what is provided in the kit is a standard 3/16 flared, but the manual states that the calipers & master cylinder are metric threads?
https://www.amazon.com/gp/product/B0...4T0SQT18C&th=1
https://www.amazon.com/gp/product/B0...XTPRDL5U&psc=1
FFR provides Edelmann 270300 English to metric adapters to use between the English tube nuts on the tubes and the metric holes in the Subaru brake hoses and master cylinders.
https://www.amazon.com/Tomkins-27030...A%2CB089F8HBFQ
Hope that helps you get going again.
RPG
Perfect thank you so much!!!
