Thanks BluePrint.
Hey all.
It was suggested to me by someone who’s opinion I trust, that I remove the oil filter and cut it open. So that is what I will do. IF there is metal in the filter, we will stop and the long block goes back to BluePrint. Ken agreed with the plan.
If the filter is clear, we are going to install my original flywheel that was tested and balanced by BluePrint. According to BP, my flywheel was out of balance by 1.4oz. (40g) If it still vibrates, the long block will go back to BP. Ken is in agreement.
If the engine no longer vibrates, then we’re done, with no explanation of why it would take 6,000 miles for the vibration to appear.
Mark
