I am finishing a Gen II build and would like to add a front bump steer kit.
FFR says they are discontinued, so no help there.
Anybody have one on the shelf for that car they got rid of years ago?
Thanks in advance
Doug
Thanks in advance
Doug
Don't know about the GTM, but when looking for a bump steer kit for my 818S, I got a bump steer kit for the Subaru donor car. Wouldn't a GTM use a bump steer kit for a C5 Corvette?
Yes/no/sort of
One end needs to fit a corvette, the end that connects to the steering rack needs to fit a mustang
Probably going to need to start with a corvette bump steer kit and adapt to the mustang rack.
The common problem here is that the 818 is not Subaru identical and the GTM is not Corvette identical. You can get those kits and make them fit the disparate components but the 818/GTM geometries are likely not the respective OEM geometry. Therefore you may have to adapt the kits to optimize bump steer. Measuring bump steer is well documented here, but finding the solution is complex.
jim
I compare my friend's amazing GTM to my 818 and the difference in the level of complexity is immense. While a bump steer kit for a Subaru donor car is about a 1/4" too short (says my respected suspension tuner), it's "good enough" (says me and my respected suspension tuner). Respect to you GTM builders.
Adding length to the outer tie rod end to satisfy bump steer really means that your steering rack location relative to your upper and lower a-arm locations is wrong. If adding spacers to lower the outer tie rod end, would mean that the steering rack needs to be raised. Obviously the opposite would apply for the reverse situation.
