I am considering the install of AC / Heater in my Gen 3 Coupe. Besides the unit FFR sells what other brands will fit under the dash?
Thank You,
Edward
Thank You,
Edward
I studied this pretty thoroughly when I did mine. I didn't find a single example that fit other than the Factory Five setup with the Siroco evaporator they use. Because of the frame design, the space is very limited. It's a basic system and works OK. Won't freeze you out like most DD's. But makes the interior comfortable. Heater works great.
I want to echo what Paul said, I looked pretty extensively to try and find a setup that would fit a gen 3 and had absolutely no luck. space is very limited behind the dash. I wound up just ordering the kit from FFR.
Erik Treves designed a system that goes behind the drivers wheel. Contact him for details,
Henry
