Thread: 33 Body dimensions
    Jul 2021
    Fuquay Varina, NC
    33 Body dimensions
    I'm sure this has been answered somewhere but I can't seem to find it.
    Does anyone have the dimensions of the main body only (height, width, length).
    For perspective, I'm awaiting delivery next month and I'm trying to install a garage hoist to store the body over head during construction, but need to know the dimension to make sure it's located properly.
    33’ Hot Rod - Gen 2. BluePrint Engine Small Block Chevy 383, carbureted, 700R4 automatic transmission
    Totally approximate with my tape measure! 30x58x105
    Jul 2021
    Fuquay Varina, NC
    Thanks!
    Placitas, NM
    Just measured mine to see if the body would fit on a friends trailer.
    61” wide x 31” high x 132” long (Gen 1 body)
    You most likely will have a Gen 2 so the length will be about 108”
    Jul 2021
    Fuquay Varina, NC
    Thanks and thanks for the picture!
    Quote Originally Posted by andyw View Post
    I was close
    Just in case you didn’t know, the gen2 doesn’t have that same front lower piece. That’s where the gen2 is much shorter.
