Just for fun I thought I would see if anyone has a MK1 dash laying around that they would be interesting in selling or trading for an MK4 dash?
How old of a Mark I dash are you looking for? I have one hanging on the wall from 1997. It was my original one before I installed a carbon fiber dash. This old dash was designed for the old mustang cut down gauges. Then I converted it to use the gauges. Would this dash help?
Ralph Button
FFR 1436 (PROUD Owner of an Original Mark I)
400,013 miles as of 11/1/2009
417,840 miles as of 8/12/2010
435,021 miles as of 12/19/2011
Now a well broken in 347 engine
523,145 miles as of 7/29/2014
601,165 miles as of 6/1/2018
615,215 miles as of 4/23/2022
"It's not about the destination, it's the about the journey. And where is your journey taking you?"
"... Not all who wander are lost!... --J.R.R. Tolkien
Factory Five will sell you a Mk1 dash with the hole for the steering column in the correct location, but I understand a swap is better for the wallet.
Mark
Possibly. I purchased an unfinished MK1 and when I went to install the dash I realized the cutout for the steering shaft was in the wrong location. I've been told it's for a MK3-4. The dash is set up with Autometer gauges which I would like to use. If your dash would accommodate those gauges then it could work in my application. The other option is to fill the steering hole and re-drill it in the correct location. The tach and speedo holes might need relocated as well. Let me know when you have an opportunity.
This is the dash I have from my Mark I
This is the OLD original dash I had in the ol'Mark I from 1997!
You can have it if it will help.
Ralph Button
