Thanks Thanks:  9
Likes Likes:  59
Page 3 of 3 FirstFirst 123
Results 81 to 101 of 101
Thread: Restoration/upgrades of FFR3490, MK2 built in 2002.
    Jan 2022
    Seven Hills, OH
    AC Cobra pedals installed. Here is my how to:
    https://youtu.be/LtMVh14eKg8?si=UCkqjJArhibT4NA0
    FFR3490 - MK2 Roadster: Yellow with black stripes, mildly built 5.0 with many upgrades/updates to come.
    See my build here: https://youtube.com/playlist?list=PL...6mVHNS3FsRV76S
  2. Likes jrcuz liked this post
  3. #82
    Jan 2022
    Seven Hills, OH
    Adding defrost vents and more prep for final dash install.
    https://youtu.be/Q66AHhBVSG4?si=igZextf6t4-DEXBx
  4. #83
    Jan 2022
    Seven Hills, OH
    Almost time to put the dash in. Defrost is done, last bits of wiring done, and more cutting/adding clearance with the frame/body.
    https://youtu.be/2BkpXYod_N8?si=T7uZbgFOeUJWmaeK
  5. #84
    Jan 2022
    Seven Hills, OH
    I thought I would have the dash in today. Last minute change for safety/reliability changed that.
    https://youtu.be/HiqUAzKL98s?si=iEgR0q6ZEGHuUAvW
  6. #85
    Jan 2022
    Seven Hills, OH
  7. #86
    Jan 2022
    Seven Hills, OH
    A little setback in getting my car back together.
    https://youtu.be/Wb-O5flIVt0?si=h4Pe-Rku4qNnPhVT
  8. #87
    Jan 2022
    Seven Hills, OH
    Back on track after my setback. Things are coming together.
    https://youtu.be/sB8y5_Snhck?si=uQlpnbBQnuMfUHlD
  9. Likes jrcuz liked this post
  10. #88
    Jan 2022
    Seven Hills, OH
    Finally done with wiring, but now have a new fitment issue with the custom dash.
    https://youtu.be/Tk7izsm3GkM?si=O0v0JrzvbyN47GKP
  11. Likes jrcuz liked this post
  12. #89
    Jan 2022
    Seven Hills, OH
    Finally done with the custom S/C dash install.
    https://youtu.be/6Dp9rbdKLdg?si=gMQtzO-nqEq674qD
  13. #90
    Jan 2022
    Seven Hills, OH
    Took the time to customize the Factory Five dash brace and make it look like a real Cobra. Very happy with the results. Here is what I did.
    https://youtu.be/dS7kNKtj8v0?si=wRsBzUMLlACwIUJC
  14. #91
    Jan 2022
    Seven Hills, OH
    Now that the interior work is done it’s time to tear down the engine and save some weight while gaining some performance by installing new heads.
    https://youtu.be/-Dkju9Gx1Bg?si=Jd5goMglJTskKLR0
  15. Likes jrcuz liked this post
  16. #92
    Jan 2022
    Seven Hills, OH
    Update on the Cobra, starting the prep and cleanup for my new heads that are going in. Full walkthrough of parts being used as well as the weight savings.
    https://youtu.be/3X2azFYSOo0?si=o6-1BV2bdmITfeKw
  17. #93
    Jan 2022
    Seven Hills, OH
    Overview of all of the required prep before installing the new Trick Flow heads.
    https://youtu.be/1uHN2ySR8LU?si=y9AsaRNRRCoOzPBn
  18. Thanks jrcuz thanked for this post
  19. #94
    Jan 2022
    Seven Hills, OH
    The heads are on! More progress on my Cobra.
    https://youtu.be/jT9FzTexRqU?si=yjK5kzkNc8g6mQTL
  20. Thanks jrcuz thanked for this post
  21. #95
    Jan 2022
    Seven Hills, OH
    More ground made, full valvetrain install with lash setup procedures and installed the intake manifold.
    https://youtu.be/szBe5ceOpbk?si=TkyrSq6g3PONOaUB
  22. Thanks jrcuz thanked for this post
  23. #96
    Jan 2022
    Seven Hills, OH
    More ground made on getting the engine back together. That much closer to the first fire with all the upgrades.
    https://youtu.be/hqtFkDn9Kp8?si=fkETvJOcK8LKlRw6
  24. #97
    Jan 2022
    Seven Hills, OH
    Making up more ground with getting this back together. I’d say 1st start is only a week or 2 away. Getting close!
    https://youtu.be/mxYGzfyojg0?si=UDhEeKzYFfqQeWl2
  25. #98
    Jan 2022
    Seven Hills, OH
    The engine assembly is finally done. Next up, first start after I set up the Edelbrock Pro Flo 4 ECU.
    https://youtu.be/eKrdryaEIk8?si=KwFdCjTMtFfsJOO_
  26. #99
    Jan 2022
    Seven Hills, OH
    After well over a year, my Cobra is finally running again after significant re-work.
    https://youtu.be/TcWRJGWxUuQ?si=aY33wzm8Sy71dUCn
  27. #100
    Jan 2022
    Seven Hills, OH
    Time to get things ready to drive this car. Fixed the tune to get it running better and working on making it road-worthy.
    https://youtu.be/IKGpPlTsafE?si=1mBtXIrFrkYA9_Gm
  28. Likes jrcuz liked this post
  29. #101
    Jan 2022
    Seven Hills, OH
    She’s back on the road! Wrapped up the last few things then took it for a test drive included in this video.
    https://youtu.be/NeQ93JklQQk?si=xkgWkhhjPv2ZLsBb
  30. Likes jrcuz liked this post
