0
0
Originally Posted by
Papa
I'd connect it. If you don't want to connect it, be sure any unconnected ports on the Sniper are capped. It's not a problem if the pot on the distributor isn't capped.
Thanks, sniper is capped at the moment. I'll just focus on the side pipes and coolant leak.
