Likes Likes:  2
Thread: Seat foam
    May 2021
    Seat foam
    I remember seeing one of our vendors had different density seat foams for the factory five seat bottom , I've searched but cant find them or does somebody have another Idea ? Thanks , Ed
    Heart of Dixie, Alabama
    Not the answer you ask for, but,,,, until you find some foam, try putting a solid barrier between the seat foam and seat frame. I used the hard plastic sheet, racers use to form up dirt car bodies. You might consider a sheet of aluminum, lexan, wood paneling, etc. It improved the comfort for me.
    It does not have to be attached. Just cut to fit.
    Good luck,
    Colorado Springs
    I used this on my Kirkey aluminum seat. Very comfortable, and easy to fit. https://www.aircraftspruce.com/catal...?clickkey=4682
    .boB "Iron Man"
    www.RacingTheExocet.com
    Quote Originally Posted by Bob Cowan View Post
    I ordered 2 sheets of this for my passenger seat. Trying to get the wife more comfortable. I bought the blue and green, medium and soft. I did not get a good report from wife. I tried them myself and found them to be less beneficial than standard foam.
    This type of foam conforms and shapes to the body. All that is good, but it compresses to an almost solid. If you have a lot of vibration, it might be more beneficial, or is combined with a sheet of regular foam.
    Not to bash the suggestion, but I had over $70 in 2 sheets and did not get the results I needed. JMO
    May 2021
    Thanks for the info , My foam is almost 20 years old so maybe I'll try replacing it , Thanks Ed
    Bill_VA's Avatar
    Manassas, VA
    I used one layer of the pink and blue foams, perfect! I can ride for hours in comfort.
    Non-donor - Engine Factory 351w/400hp - TKO500 - 3-Link - Cobra brakes - FFmetal - Wilwood pedals - FR500 wheels - NCPainter
    Owner of FFmetal.com
  7. Likes Railroad, Bob Cowan liked this post
