Results 1 to 8 of 8
Thread: Limited Access?
    Falmouth, MA
    Question Limited Access?
    Just picked up my partial built 818 and spent the day going over what needs to be completed. After reviewing everything and digging through the build manual I've found several issues that I'm hoping someone else has found a good solution:
    --- The brake and clutch reservoirs, how do you access them after the dashboard is installed? Has anyone used a remote reservoir?
    --- The overflow tank and the fill port for the anti-freeze; I can't get either cover off since they hit the frame. The overflow tank can be moved but what about the fill cover on the engine block?
    Fenton MI
    Most trim the windshield surround for access to the reservoirs.
    As far as the coolant tank, Craig makes a lot of great 818 products. http://zerodecibelmotorsports.com/pr...elocation-kit/
    Factory Five 818c #456
    Feb 2019
    Houston, TX
    Take your time and trim the cowl neatly and it will look good. I saved the piece I cut out and will fabricate a magnetic mount for it.
    Falmouth, MA
    Trimming the cowl was the only way I could think of without a remote fill. Michael Everson had at one time looked at developing a remote kit (googled on the 818 forum). Did this ever come about?
    I use a very long funnel + flexible hose to fill the overflow tank (it's even less convenient to get to in the C)
    Mar 2014
    Hingham, MA
    Quote Originally Posted by cob427sc View Post
    I'm one of the lucky ones who got one of Mike Everson's remote fill kits back when he was making them. It's not too complicated. Just some low pressure fittings into the master cylinders connected by hoses to a remote reservoir.
    Falmouth, MA
    Where did you get the caps for the cylinders which would replace the stock reservoirs?
    Mar 2014
    Hingham, MA
    They were part of Mike's kit. I can't get a decent picture, but they are aluminum fittings with o rings held to the MC with a piece of Al tie wrapped (I used safety wire) down and around the MC. Maybe Mike will make some up if several people agree to purchase.
