FF33rod
Great progress! Love seeing this come together.
WHEELS - Foose has difference construction available - 1 piece cast, 2 piece cast, forged,..... The 1 and 2 piece cast are the least expensive. Knuckle is available at a reasonable price as one piece cast but with limited specs. I suspect Papa is looking at the more expensive forged option where knuckle is also available. Specific designs seem to come and go from the different line ups. The Coupe design that I got in 2 piece cast with a custom offset are no long available in that configuration...
Battery BMS - what are you doing for a BMS (Battery Management System)? I've seen hobbyists neglect and cheap out in this area which is not good with such a large capacity pack...
Thank you!
I'll dig in to those wheels a bit more.
I ordered the Dilithium BMS. It's on backorder but should just be a few more weeks. It will interface with the EV Controls T-2C controller. Definitely not an area to cheap out or ignore!
