0
0
Gel Coat Repair Kit
My car came with minor damage/missing gel coat on the right front corner.
I wasn't going to worry about it as I figured that painter would take care of it. However, since it's quite possible I'll be driving the car in gel coat to start, I need to get this cleaned up and repaired. Is there a recommended gel coat repair kit I should use?
Jack
Jack
289 Roadster complete kit ordered 8/2/21. Delivered 3/14/2022. Chassis #10306. 17"x9" Halibrands, 3.55 IRS, PS, Wilwood brakes, BPE 306 with EFI and close ratio TKX. First start 7/20/2023. First Movement 9/24/2023. First go-kart 9/25/2023.
Build thread -
https://thefactoryfiveforum.com/show...rida-289-Build
- You may not post replies
- You may not edit your posts
Forum Rules
