Results 1 to 3 of 3
Thread: autometer speedo help with coyote
    Mar 2018
    Bradenton, Florida
    I started my build in June 2018 and tomorrow I'm going for the dreaded Florida DMV inspection to get it registered as a ASPT, what could go wrong???
    I got my temp tag today so that was a win and I am ready for my inspection although I can't get the speedo calibrated.
    From what I understood I don't use the green and grey wires of the Ron Francis harness or the Tremec speed sensor but instead use the green and grey wires that came with the coyote wiring that are part of the coil/crank harness.
    When I go to calibrate the speedo everything does what it is supposed to do (it even counts the pings while I'm driving the 2 miles like it's supposed too) but when I hit the button after the 2 mile drive, nothing, it doesn't work.
    Not much info online and some contradictory advice to confuse me more.
    Any advice is welcome!
    Your non-GPS Autometer speedo gauge (assuming that's what you have) has to get the pulse from the speed sensor in the transmission. Not the engine. Not sure what Coyote wiring you're referring to. But there's no connection between the Coyote and the speedo gauge. Tach, yes. Speedo, no.
    Mar 2018
    Bradenton, Florida
    It works! I used the speed sensor wires on tranny and the RF harness but the grey wire must be grounded, not hooked up to speedo "out" connector (nothing goes to that)
    The RF harness also has a set of speedo wired for EFI but after looking at wiring diagram they are connected to the other speedo wires so not sure what they are for, i just capped them off.
    My speedo now says i have 358 miles??? is there any way to calibrate the miles? and every time i calibrate the speedo will it go back to 0 (or in my case 358)?
    This type of speedo does not use the red memory/clock wire correct?
