Likes Likes:  23
Page 2 of 2 FirstFirst 12
Results 41 to 52 of 52
Thread: BA's MK4 build thread by Wallace18
    Got out early today to beat the heat and because I have Doctor appointments and such. I was able to trim hood for initial fitment. I use a 1/8" tape then trace with a Sharpie. Then use a belt sander to the line. I also mocked up scoop and cut hole in hood.
    B6EDA898-4D98-44F1-AB82-A535EF08B9D3.jpeg9E25BB4A-5439-44C1-988F-639394714B84.jpeg7152AEC3-4D3F-45CF-AF05-280111C64318.jpeg009A5432-F2C2-48C6-88A3-428FF65061C0.jpeg4C3547A0-A155-4CA9-A7C9-8E60092C75A4.jpeg1DD047F2-BE04-4201-971F-AE22DFEBB22A.jpeg
    16+ FFR kits and counting!
  2. Likes FF33rod liked this post
  3. #42
    Finished up the hood today. Opens and closes fine. I installed the Replicaparts radiator panel that the owner bought. I had to trim a-lot to get it to fit and add some of the FFR panels to have a good fit to the body. I also mounted and plumbed the oil cooler.
    B6DA7459-4F95-47EE-A295-F5BBF49CD577.jpeg7AA01538-F98F-4F3F-A915-E633BB7AABAB.jpeg966EBC6C-EE6D-411D-875D-754FC310CECB.jpegFAEBEEC0-ECDE-4FEC-A291-16FB30C37AF4.jpeg
  4. Likes FF33rod, CaptB liked this post
  5. #43
    Today I worked on the front. I installed and wired up the front lights, Installed front top radiator cover and mocked up front splash shields. I will coat them with black truck bed liner before final install. I also finished up trunk. Unfortunately the trunk bulb seal came apart like the other bulb seal. I will have to order some from McMaster-Carr.
    05E07948-F5EC-4B60-82A9-3512A15A60F1.jpegA5E2B547-4098-4396-91D8-67866966FE08.jpeg04D7C9B0-FD82-4A7A-93E4-D12834F2D51D.jpegE699E70A-0682-46A0-A3B5-401B2A9C25C0.jpeg0253CA95-F92F-4AB9-B10B-E55F3AA52BB0.jpeg
  6. Likes CaptB, FF33rod liked this post
  7. #44
    Trimmed and mounted both doors. Finished up the passenger one. Opens and closes like a dream. Not sure who is doing the QC at FFR. This is my 6th MK4 and the steel insert on both doors is not in the correct position. I can only get 3 screws in each side for the latch. I will have to come up with some sort of fix for this. Never had this happen before on any of the 5 previous builds. All part of the fun, LOL.
    95FB978B-AA76-45DA-853B-CC28C0A046A2.jpegD1D08860-A991-447A-B9CA-BEB62E87CAC7.jpeg2BC421A8-3654-4709-A76B-78F85081E973.jpeg
  8. #45
    Finished up drivers door. I had to add metal to inside door so all 4 screws had metal to grip to for latch. Door panels really make the door, IMO! I also slotted the underside of the body so proper door alignment can be obtained by body shop down the road. I installed riv-nuts in frame for S/S screws.
    A91CBE72-4A75-4FD1-9220-818459172317.jpegE68BE70B-9C02-4BC8-9062-28AA0D286511.jpeg398B1616-6C26-4026-9BEF-5753C91640C3.jpeg9D5ECC0F-AF3B-4D18-AC10-085FDA49EF30.jpeg
  9. #46
    Installed side pipes and tightened all associated bolts. Sounds good! Hope to install windshield tomorrow.
  10. Likes FF33rod liked this post
  11. #47
    Installed door checks. Sealed up body to foot box gaps. See before and after. Pool noodles and rubberized undercoat. Installed front splash shields.
    73C2C1E5-6A48-41BF-ACDC-D136F16D3202.jpegF876E904-7203-4856-BBA2-6663DAE3CD99.jpegBE1BE846-EA3A-4CE4-8ACE-9776A9E34EF9.jpeg93567E0D-65F8-4576-8818-37D076601CD7.jpeg
  12. Likes FF33rod liked this post
  13. #48
    Today I finished up the under door aluminum and carpet. Then I mounted windshield. I threaded the arms as I saw listed by someone else. What a great idea, Thanks! Installed wind wings and center rear view mirror. Not too much left to do.
    9E3A031D-511E-4A9A-80EB-437DC8732D81.jpegE2A33880-0C83-4C89-845A-6B0E5C5467D4.jpegFBD7F444-138F-425E-BC6B-990D86893A3E.jpeg220BD791-34CA-48F6-AD2B-1E1B1DF7EF0E.jpeg88F6D73C-B787-4519-ADD4-A708EF29F7BF.jpegB8A28599-55C3-41D4-A952-93766C09EA84.jpeg
  14. Likes CaptB, FF33rod liked this post
  15. #49
    The new bulb seal from McMaster-Carr came late yesterday. I installed it and made up my own trunk prop rod. I use some Velcro to hold when not in use. Not sure why FFR does not include on. 33 has one. I installed original steering wheel. Also painted the Replicaparts radiator surround as per customer. Took car out for a road test after setting up ride height. Came back and 90 degree coolant fittings on heater bypass hose both leak. I ordered 2 new ones from NAPA. Due here later today.
    54D8F735-6CD6-4A4E-9616-7FADDBBEDF46.jpegDC494B2C-7805-406B-B250-C70E1F2BB84D.jpeg34BFD109-BE59-45F3-92A0-6ACE9E09E272.jpeg8965B85E-1058-46C4-8074-0770FA0E0A2E.jpegC6A7504C-8C4D-4D1E-9273-F7549DD05F0F.jpeg47E50291-E25E-4922-8AEC-CFF97B557542.jpeg
  16. Likes FF33rod, CaptB liked this post
  17. #50
    Replaced the 2 leaking coolant 90 degree fittings. All good now. The owner is going to black out all chrome on car . So I am not mounting side mirror. Florida law states car must have 2 side mirrors, he is going to buy 2 black ones. I cleaned up car and vacuumed it out. Double checked everything. All is good to deliver next week to owner. I will be taking some time off after this build to go camping and traveling. It has been an enjoyable build. My first Coyote build. I am impressed with the performance of the Coyote.
    3145DD5F-67AC-43AA-9A24-44CD08929F58.jpeg697736D0-497C-4AD5-B591-73D4F80470D8.jpegF52B5A5C-0194-4253-8432-A467949B0F90.jpeg47C3067C-C92E-459D-9D6F-DFA4B13C8A57.jpeg37A7D9FD-C84E-4CBC-9837-4D8695D6074B.jpeg
  18. Likes Windsor, rustyrim liked this post
  19. #51
    All loaded up and ready to deliver to South Florida next week. Upon delivery it will be 76 days from drop off to delivery.
    Actual work days is 50 days 4-6 hours a day.
  20. #52
    Delivered MK4 to BA and his son's today. They were very excited and pleased. BA took it around the block and was all smiles. Mission accomplished, LOL. I forgot to take pictures. My bad!
