Results 1 to 8 of 8
Thread: Interior Door Panels- How did you install?
    Mar 2018
    Hello everyone, I am at the part where I am installing my door panels. I know there are many different ways to do this but I like the clean look with no bolts. I am not sure how you all installed yours. Did you use button head bolts? Velcro or etc..... Thank you
    Falmouth, MA
    I used stainless screws 10/32 with rivnuts.
    Mar 2018
    Also, I notice the door panel for the 33 does not fit too well. Its like its not the right size in most areas. You guys have this issue as well?
    Jun 2020
    SoDak
    I used trim screw to hold mine in. I also installed speakers in my panels so with the aluminum door panel, vinyl & speaker mounted, the panel was too heavy for velcro and I was not sure how the hidden snap clips would work in the fiberglass.
    Regarding door panel fit, yes, you will need to reshape it some to fit properly. The door shell itself is not flat (it's deceiving an looks like it is but look down the surface), so you need to make sure the panel follows the angles / contours of the door panel. Kind of a pain to reshape it, but once you do it fits good.
    Jim
    Falmouth, MA
    You qill need to bend the panel to fit the curve of the doord I used a couple of 2x4 on the floor and stood on the panel, a little ata time to get the shape. You are correct that the aluminum doesn't quite lineup with the door shape around the panel. I was able to hide some of it by sliding the panel up and forward, then added carpet on the bottom half of the door which concealed the gaps.
    Jun 2018
    North Vancouver, BC, Canada
    Gen 1 '33 Hot Rod #1104
    Mar 2018
    Thank you guys
    Foristell Missouri
    I have a gen 1 that had aluminum panels that did not fit well. I remade panels out of the waterproof door panel material sold at upholstery shops. I used the original panels as templates and adjusted areas on the new panels that was not sized correctly. I sewed up new roll & pleat skins that had a little more definition and attached them with clips used for marine applications called beau-clip. They fit blind and work quite well.20170918_163752_resized.jpg
