Thanks Thanks:  2
Likes Likes:  5
Results 1 to 5 of 5
Thread: Heim Joint play
    Edmonton, Alberta
    Heim Joint play
    At first I thought I had a bad wheel bearing, but after noticing I only had play up and down and not side to side I narrowed it down to one of the FFR supplied heim joints. Anyone else experience this? Any recommendations on a replacement? Speedway has a few options to choose from and I’m not sure what is an upgrade and what isn’t.
    818 SRX - #91
    Arrived 01/02/2014
    First Start 10/31/2016
    First Drive 05/22/2017
    Registered 10/25/2019 BRAP818
    Mar 2021
    SE WI Kettle Moraine
    Years ago I worked for QA1 when their primary product was rod ends sourced in China. Their claim to fame was rod ends with a plastic medium between the ball and the housing.
    https://www.qa1.net/automotive/rod-e...oints/rod-ends
    The advantage is two-fold, the plastic acts as a seal against dirt abrasion and as a resilient shock adsorber to reduce pounding-out of the ball/housing tolerance.
    I have had good service from their products.
    BTW cost is usually an upgrade.
    BTW Resilient bushings in a suspension reduce "nervous" behavior at higher speeds and they reduce NVH in the chassis. Not all racing stuff is ideal for the street.
    jim
  3. Likes Canadian818 liked this post
    Edmonton, Alberta
    Thanks Jim! Looks like there’s a dealer near me so that works out perfectly.
    818 SRX - #91
    Arrived 01/02/2014
    Here's my post on joint play:
    https://thefactoryfiveforum.com/show...nd-replacement
    Moving all joints over to FKs soon.
  6. Thanks Geoff H thanked for this post
    Likes Canadian818, Santiago liked this post
  7. #5
    Feb 2018
    Half Moon Bay California
    FK rod ends are the goto units in the off road industry which tortures these things. My FFR unit was also making noise and with the FK it's all quiet.
  8. Thanks Geoff H thanked for this post
