Thanks Thanks:  3
Results 1 to 4 of 4
Thread: 4 Post Lift and 33 Hot Rod Anyone?
    Senior Member svassh's Avatar
    Apr 2021
    Highland Village, TX
    I'm picking up a mostly assembled kit tomorrow. Its not running but I have a electric hoist to pull it onto the lift. Question for you guys with the Hot Rod and the lift.
    Can you drive it onto the lift without the front grill hitting the lift?
    I have some additional ramps to reduce the angle of approach if needed.
    MK2 Roadster - 347 - Boss 302 Crate 4x2 Weber 44 IDFs
    Mar 2018
    I have a 33 hot rod and also a 4 post lift. I have no issues with the radiator hitting. It does seem like it would but mine clears pretty good. Hope this helps. My ramps are just standard ramps and you could always make them longer.
  3. Thanks svassh thanked for this post
    i put mine on my Bendpak 4 post all the time with no problem
  5. Thanks svassh thanked for this post
  6. #4
    Jun 2020
    SoDak
    Same on my Eagle 4 Post Lift, no issues what so ever. I can even drive our 08 C6 corvette on and off the lift too with no issues (on standard ramps) and that is even lower than the 33.
    Jim
  7. Thanks svassh thanked for this post
