Thanks Thanks:  3
Results 1 to 13 of 13
Thread: 302 Pulley does not fit. Wish I knew the restrictions.
    Oct 2021
    Curtice, Oh
    So I bought this nice pulley kit a few months ago. Got it all fitted and looking good. Now I dropped the engine in and the alternator hits the frame.
    https://www.cvfracing.com/ford-289-3...ternator-only/
    How do I solve this without having to throw this whole kit out? I wish I would have ran across an issue like this in the forum before. Hopefully someone has solution or at least someone may see this and know it has issue.
    If I have to purchase another one what have others used that works?
    Dublin, OH
    can you extend that tensioner to swing the alternator further up towards the PS, thus clearing that angled bit of the frame?
    Oct 2021
    Curtice, Oh
    Don't know why I did not think of inverting the alt. If I shorten the ground nut on the back if the Alt. and make a new tensioner center section, I think I can make this work. Just have to figure out how long of a belt and buy a new one. Hopefully this will not interfere with the body in any way. I will be using the side panels. If I get it to work, I will post final pics.
    Oct 2019
    Erin, Ontario CANADA
    Hey Jeff, when I was building my 302 I had the alternator low-mounted like you did and sharp eyes told me to flip it just as you figured out. If you need anything in the way of different spacers to make it work a call to CVF will fix that. Their support is great and the main reason why they have me as a customer for life now.
    Earl
  5. Thanks Jeff33Ford thanked for this post
    Kingsland, TX
    Quote Originally Posted by Jeff33Ford View Post
    You should be able to flip the lower bracket so it curves up instead of down.
    Also make sure you have a late-model style thermostat housing that exits 90-degrees up, not the early-type 15-degree.
    Simi Valley, CA
    I suggest that you be cautious inverting the alternator. The built-in fan is highly directional - if you spin it backwards it will not pull as much cooling air through the coils, leading to overheating and early failure. FFR recommended mounting the alternator inverted for Coyote installations in the Hot Rod, but they also recommended an alternator designed to spin the opposite direction from stock. Maybe you can change the drive belt to spin the alternator the correct direction?
    Keith HR #894
    Oct 2019
    [QUOTE=progmgr1;497662]I suggest that you be cautious inverting the alternator. /QUOTE]
    Inverting the alternator does not change the direction of rotation, but changing the direction of rotation of the belt driving it does.
    Oct 2021
    Curtice, Oh
    Yep. No change there. Belt still will only have 3 points of contact.
  10. Likes narly1 liked this post
  11. #9
    Dublin, OH
    longer belt and different water neck/tstat housing and you should be good to go
  12. #10
    Jun 2020
    SoDak
    Will need a longer tensioning strut rod too.
    Jim
  13. #11
    Oct 2019
    Jim
    I was able to get away with using the existing tensioning strut rod, but I also got a new (likely shorter) belt.
  14. #12
    Jun 2020
    SoDak
    Quote Originally Posted by narly1 View Post
    I routed the heater hoses behind and on the side of the alternator so mine sticks out a bit further thus the longer tensioning strut rod. I also needed a longer belt.
    Pics are from initial assembly, I just discovered I don't have any recent pics with it all finished, I'll need to take some.
    Jim
  15. Thanks Jeff33Ford thanked for this post
  16. #13
    Oct 2019
    Jeff, I just realized that you are running the same pully set-up as me.
    In my case all I had to do was get some different spacers to get everything to line up and as previously mentioned, a shorter belt.
    For hose routing I was able to take the one barb fitting out of the water pump and insert a brass 45 degree street elbow in between. This left lots of room underneath the alternator for the one hose. The other hose comes out of the water pump and makes a sharp right angle turn into the thermostat housing.
  17. Thanks Jeff33Ford thanked for this post
