I need to get the proper size for stock shocks. Looking for 500 LB rear springs, does anyone have a good source and part number.
This is the part number for Eibach springs in the size/rate you're looking for: Eibach 0800.250.0500 - Eibach Coilover Springs.
I ordered these and have installed them in my 818 using the base level Koni's.
Also Pegasus has Hyperco springs in the 2 1/2" ID, 8" long that I think is the required size.
I have springs from my roadster. If they are the same, you can have them. I got the koni double adjustable, but received a couple extra springs in my kit for some reason. Jut not sure if they are what you need.
