I have a Gen 2 street rod with new Moser 8.8" rear end 4 link setup, no fenders (at this time, hope to go bicycle route soon). A couple of things have me perplexed as it relates to the rear suspension. Clearance from top of tire to body is 1 5/8" on driver side, 1 1/4" on passenger side. Running 315/35R17 on rear. Trying to get more clearance but I run into my driveshaft hitting the floorpan??? I guess my question is, What hole should I be using for the lower and upper control arms? I can adjust the angle of the pinion some by changing to different holes but have concerns of pinion/transmission relationship, dont want any vibrations. But this adjustment might give me a bit more clearance on the driveshaft. If I am the only one with this problem on the Gen II then I must have something wrong. Any suggestions or insight would be greatly appreciated. IMG_0653.JPGIMG_0654.JPGIMG_0655.JPG
