Thanks for the clarification......I would not do that since removing the bolt would require the header to come off - and I put the headers on before the mounts - so it isn't possible - there is room - it's just close - as long as it doesn't touch it's good - you could change the nut type and go to a metal lock nut versus as nylon lock nut - they tend to be shorter and narrower...
