After many delays, seems like my kit will finally reach me in about 2 months’ time. Reserving the spot for my build diary.
I have previously built 2 Lotus7 based kit cars but got rid of them after driving them both for less than 1,500 miles, very fast and fun cars, but something just did not sit right with me. Hopefully, this will not be the case with this kit
I do not intend to properly track the car (maybe an occasional track day or 2), nor do I want the car to be very civilized - this is just an obnoxious summer weekend car.
My expectations for this build is to have everything I need to complete the car and I intend to have it completed for the summer. If anyone notices something which is not in the list below, but is needed to complete the build - please let me know (getting parts to this part of the world is not easy and I don't have patience)!
Specs:
60744 - Powder coated chassis - Black
60510 - Coupe GPS Metric Gauges (kmh)
16787 - LS Mounts
16813 - Headers: LS-series stainless steel 4-port full length with ball flange collector
34158 - Hydraulic Clutch Master Cylinder Kit
16038 - 31 Spline 2015 IRS 8.375" Driveshaft
12070 - Body with cut-outs of side pipes, body mounts, lighting accessories, gas cap, and side openings
13852 - Upgrade: Competition High-Back Aluminum Race Seats with black fabric covers
16799 - Power steering kit
12066 - Standard Width Tubular Front Lower Control Arms
60737 - 2015 Mustang-based Independent Rear Suspension Kit with KONI coil-overs, tubular control arms, and CV axles
60377 - A/C – Heater- Defroster for 302/351W
60364- Coupe Interior Black Carpet Package, pre-cut
15760 - 14” Leather Steering Wheel Upgrade
60371 - Coupe Side Windows
60831 - Gen 3 Coupe Floormat
60835 - Coupe Sound Insulation Kit
12453 - Battery Cutoff Switch
16116 - Front Swaybar
15998 - 2015 IRS Rear Swaybar
15812 - Vintage Halibrand Replica Wheels, 18” X 9” Front and 18” X 11” Rear
15996 - Upgrade: Double Adjustable KONI Front and Rear IRS Shocks (set of 4)
16668 - 2018 Mustang IRS 3.55 Center Section, Spindles, and Hubs
15370 - 12.88” Front Wilwood Brakes, Red Calipers, Drilled & Slotted
60850 - 12.88” 201215 IRS Wilwood Brakes, Red Calipers, Drilled & Slotted
33015 - Hotrod/Truck LED Headlights
80856 - Race Side View Mirrors
BLUEPRINT ENGINES BUILDER SERIES 427CI PROSERIES STROKER CRATE ENGINE AND T56 MANUAL TRANSMISSION | GM LS3 STYLE | DRESSED LONGBLOCK WITH FUEL INJECTION | ALUMINUM HEADS | ROLLER CAM | DELUXE DRESSED LONGBLOCK W/ PULLEYS POLISHED - BLACK 625 HP / 565 FT LBS
Other parts:
Russ Thompson Turn-signal system
Holley 12-132 455lph in-tank fuel pump
Nuke Performance/Fuelab Fuel pressure regulator
Nuke Performance/Fuelab in-line Fuel filter
RedHorse PTFE AN6 SS lines and fittings (no hard lines)
Oil Catch can (TBD)
Back-up camera (Autovox v5 Pro, Wolfbox G900 or similar)
Wheel spacers (TBD)
Tyres - 275/35 and 315/30, (r888r, Pilot Sport Cup 2 or similar depending on availability)
Plans for the build:
Leather interior
Custom switches and A/C controls
Additional sound insulation
Powder coated panels
Depending on choice of body colour (considering Candy Apple Red, Verde Mantis Green, Arancio Bruciato Orange), might need to paint wheels and exhausts.
Any suggestions and tips are very welcome!
