18
63
mkassab
OK, need some advise/help on the Coyote clutch switch that comes with the Coyote ECU pack and the FF Coyote install kit.
In the attached picture below, I added a yellow arrow pointing to the Coyote clutch switch and the FF mounting bracket for the clutch switch. The FF manual shows how to install as I have pictured, but nothing I can see on what engages the Coyote clutch switch.
So, I'm looking for any thoughts or direction on how does it work?
Thx Mark
I found out what I needed.... I'll document what I did soon
Thx Mark
