03-24-2024, 07:46 AM
#241
03-25-2024, 07:55 AM
#242
03-27-2024, 08:14 AM
#243
04-01-2024, 07:57 AM
#244
04-03-2024, 08:16 AM
#245
Cab roof ribs added
Quick update.
Striping the old, flaking LizardSkin product was easy in some spots and very difficult in others. I ended up using my pressure washers to strip the difficult areas.... worked well. As I was cleaning, I was also thinking about the final finish for the roof of the cab. I decided to add some wood strips (ferring strips) to attach the roof cover to.
I simply ripped 1/2" strips from a 1 x 4 pine board and glued them in place with 3M 5200 polyurethane and weighed the strip down to match the contour of the roof.
I'll then cover the wood ribs masking tape and respray the cab with the two LizardSkind sound and heat products.
More later on all this,
Mark
04-05-2024, 08:09 AM
#246
Cab interior covered with two products for sound, vibration and heat
After cleaning and scuffing the cab's interior, I changed my mind on the LizardSkin. I had other sound and heat options from other builds I've done. And to be very honest, after my bad experience with LizardSkin peeling off and my plan to glue my interior cover to the side walls.... well, I was very concerned about the interior side cover not staying in place because of my fear LizardSkin would fail over time.
I first cleaned all the interior surfaces again with Acetone. Then proceed with a Dynamat type butyl rubber backed by aluminum foil.
Then I covered most of the foil backed butyl rubber with this product.
This material is about 1/2" thick, heavy dense foam backed by a very sticky adhesive. Both the butyl rubber and foam will be great for sound, vibration and heat.
I also covered the back panels with the foam mats.
Lastly, I cut 1/4" lauan plywood to fit the roof that I'll cover with the diamond padded vinyl for the finish look and a fiber material for the sides. I'll add this after painting. Then I'll set the completed interior cab back on the chassis. It's much easier to do the interior while the cab is off the chassis.
Some of you may be wondering why the gap in front of the plywood. Well, you may recall from earlier posts I made an overhead gauge panel that fit tight to the cab's roof.... so, I had to leave room for the gauge panel to fit
Stay tuned,
Mark
04-08-2024, 07:15 AM
#247
Truck Cab base frame made and installed
Since I'm doing my Cab's body work and paint off the chassis, I had to build a frame system for the bottom of the cab to stiffen it up, with the cab to be up off the ground and be able to move it easily by myself.
Came up with the design below
I didn't want to drill holes in the cab's base, so I used fender washers to hold the cab to the wood frame
In the picks below, note the long front to back runners.... they are 30" apart, the same as the moving dolly I have. I simply clamp the dolly to the frame to hold in place while I roll the cab where I want it. Then, I can unclamp it, lift the front of the cab to tilt backwards and simply remove the dolly for a firm cab stance on the ground for sanding, etc.
When I'm done with body and paint, I'll place the cab on my lift's arms to complete the interior while comfortably standing inside the cab. I'll also use the lift to lower the cab back on the chassis.
More to follow,
Mark
04-15-2024, 07:50 AM
#248
Stack Pocket mounting to Bed Sides
During my body work on the bed side panels, I had to add some "parts". You might recall that I bought from FFR the Stake Pockets option. Well, by installing the pockets you hide the rear mounting area and, thereby, can't access the mounting button head screw. So, my fix was to install a couple rivnuts to each of the rear side panels so I can install the screws from the inside vs the outside.
Since the side panel has pretty thick fiberglass and the upper hole also had the ss wrap, the standard rivnut wouldn't work, i.e., not enough grip area was exposed for proper rivnut expansion..... so, I found this type of rivnut which worked out great.
In the next pic, I bonded the stake pocket to the bed side with 3M's High Strength Repair Filler (HSRF). I scuffed up the bed side and stake pocket mounting surfaces with 40 grit and applied the HSRF to the stake pocket and pressed on the pockets to the bedside. 30 min's later, I was cleaning up the HSRF that squeezed out. I'll show the finished panel later in another post.
More to follow,
Mark
06-04-2024, 06:36 AM
#249
Why no updates?
It's been awhile since my last update.... well, a lot is happening. We decided to cash in on the housing market in our town and downsize. Our house when for sale about 30 days ago. We're moving to NE Tennessee by Johnson City, TN. We found a great home with a shop for me. So I decided to but the build on hold and finish the truck in TN. I'll keep updating as appropriate.
Thx Mark
08-19-2024, 07:37 AM
#250
10-04-2024, 08:21 AM
#251
Hi Mark,
I'm finally getting around to installing my grill cowl. And I found large gaps at the sides after the top edge was fitted. Sounds like I have the same problem you had with it being aggressively trimmed at FFR. I'll email them today and see what they say.
But I have another question: Did you use that T shaped piece of aluminum that is supposed to mount the lower chin of the cowl to the frame?
Thx for taking the time to reply,
Reason: ignore question on screws
1990 Mustang 5.0 5sp, 2021 Bronco Sport Badlands, 1935 Extended Cab Build, 347 & 4R70W
10-04-2024, 10:06 AM
#252
Hey Don.... I did use the T-Aluminum..... however, as I stated in my posts, I had to trim the lower fiberglass and make my own support to hold the lower cowl together.
Mark
11-03-2024, 09:58 AM
#253
Mark,
Did you have any issues getting the hood hinge to line up? I'm noticing that the hinge arm is perpendicular to the radiator but the hood bracket (that mounts to that hidden aluminum block) seems to be at a very different angle. Did you have to re-bend the bracket or hood arm?
Seems to be off by 13 degrees or so.
Or maybe I'm missing something.
11-03-2024, 07:05 PM
#254
Don, send me your email and I’ll send you photos of how I dealt with this issue. DonS.
11-04-2024, 06:36 AM
#255
Don, I did have to bend and shape each hood hinge bracket/arms.... A few twists and bends. I took my time, test fit and off again as need to get each side perfect. A large bench vice will be your friend here.... I also use an adjustable wrench for the twisting. Happy to discuss if needed via a phone call.
Good luck, Mark
11-14-2024, 12:33 PM
#256
Originally Posted by
mkassab
A few more items showed up yesterday.
First up, I received my engine side cover vents. I had then clear anodized which should help with preventing corrosion. These will allow the small engine compartment to dissipate some heat and I think they look good and period correct. I also plan on wrapping the headers/exhaust pipes and shields atop the mufflers (I have this stuff on order also).
This last pic shows two products, 1) Lizard Skin, a heat and sound proofing system with spray gun, and 2) Raptor protective coating and spray gun (like truck bed liner). I'll spray the Lizard Skin in the cab (e.g., cab body, floor, door interiors and firewall). I may also do the underside of the hood and engine side covers. For the Raptor product, I'll spray the underside of the 4 fenders and running boards. I'll most likely also spray the underside of both the floor pans and truck bed.
Stay tune, "stuff" coming in each day/week.
Mark
What was the sorce for your side vents? I am having heat issues and I think I need to add side hood vents to help in cooling the engine bay.
11-15-2024, 07:50 AM
#257
Grandpa... here's the link: http://www.streetdreamsbyross.com/vents.php I bought the same vent that Paul did for his '35 truck. I also had the grill vents "anodized" by Street Dreams.
Good luck,
Mark
01-14-2025, 08:20 AM
#258
01-15-2025, 10:55 AM
#259
01-15-2025, 11:29 AM
#260
Thanks Lewis. It your truck painted and complete yet?
Mark
01-26-2025, 08:40 AM
#261
Interior start and cab preinstall questions??
To finish my build, I need to complete body and paint (along with my interior)..... but, I need the weather to be warmer to do all the prep/sanding outdoors so I don't "dust up" the entire shop. So, I'm focusing my "winter time" to wrap-up the interior as much as possible. I shared a few pics below of my start, i.e., Carpet and Speakers. I'm upgrading my carpet from FFR's supplied carpet (I'll use FFR carpet as a template, after I fit it, to cut the new carpet). It's better carpet and more "period correct". I started on the back panel where I have a pair of tri-axial speakers and a pair of subwoofers. I also have speakers for the cab front I'll show later.
However, I do have questions on what I can do before the CAB is put back on.... examples, can I install the dash, the seatbelts/shoulder belt brackets to the roll cage, etc. I'd like to also install the roof liner before the cab is put in place??
INPUT needed to the above questions. Any thoughts, cautions, got-yas most welcome!
Thx Mark
BACK PANEL:
Passenger Side floor:
01-26-2025, 10:18 AM
#262
No on Dash preinstall prior to cab install
OK, I just answered one of my questions..... you can't install dash before the cab as the dash bolts to the cab flange along the door opening and preventing the cab slipping behind the dash flange.
Mark
01-26-2025, 02:49 PM
#263
Howdy Mark.
Now it might be because my truck was an early build (sn# 0059) and it might be in part the mildly affected right hand from a stroke a few years prior to 2019 when I was building the ‘35….
All that aside I can recall terrible access to one of the upper door hinge bolts to frame…don’t recall now whether it was just LHS or both.
Can tell you if i were to do it all over again the temptation to drill holes in the doorframe and/or change assy instructions and weld a nut or two to the backside of the supporting structure (on the body frame) for the door and put a bolt in from the opposite side from recommendations…would be very tempting.
This as mentioned, could be my experience only…but it’s very little time for you to do a ‘dry run’ whilst the body is still off.
My 2 cents…hopefully helpful.
Pat
Once again with an 88 mm Turbo, Big Block Chevy powered, ‘35 Hot Rod Pickup
01-27-2025, 07:25 AM
#264
Thanks Pat.... you are correct, if the dash was in place, the upper inside hinge bolts would be impossible to get to..... so, no dash until the cab and doors are in place.
Thanks for your comments,
Mark
01-29-2025, 09:35 AM
#265
Front and rear dash prep install
While installing the interior, I had to complete all the wiring, e.g., speakers, security alarm and my front and rear dash cam.
The pic below is the unit being installed. The rear camera plugs into the main front camera. Both front and rear camera views are displayed on the color lcd monitor on the backside of the front camera. Also, the main mount has GPS and the GPS position is also recorded. This unit was highly rated during my research.
Mark
01-29-2025, 02:58 PM
#266
1935 Tenn Tag and Registration
I just wanted to share the end results of me registering and titling of my '35 Truck.
As the pic shows, my tag and registration, Tennessee registered and titled my truck as a 1935 Ford F5R. I bought the '35 License Plate/tag off eBay and they used it. And since it's an antique, it's a permanent tag with NO yearly registration fee. Also, they used FFR Ser # for my VIN. Lastly, no inspection in any way shape or form was required!
I couldn't have asked for anything better.
Mark
02-01-2025, 08:35 AM
#267
02-04-2025, 09:57 AM
#268
A great way to bleed brakes and hydro clutch
I'm sure many of you know and/or use this Motive Products device. For those that don't, you just select the cap that fits your brake fluid container(s), fill the Motive jug with brake fluid, pump to put positive air pressure in the jug to ~5-10psi. Then just open the bleed valve on each brake caliper or clutch throw-out bearing bleed hose. Keep open until all air bubbles are gone and you'll have perfect, 1-man, blead brakes.
Once you use this, you'll never go back to the "old" way to bleed brakes.
Mark
02-05-2025, 08:04 AM
#269
02-06-2025, 08:52 AM
#270
mkassab
Mark
Nope. Waiting on weather.
02-14-2025, 08:23 AM
#271
Tach Signal for Dakota Digital tach with Coyote engine
I'm using Dakota Digital gauges/Tach with my Ford Performance crate engine and ECU. I tried to pickup the tach signal from one of the coil pack neg (-) wires and the tach was very sporadic (i.e., sometime showing the correct RPM and other times jumping around and/or freezing).
After reading many threads, I determined I needed a tach signal adapter to pickup a tach signal from the Coyote's ECU/PCU. There are several adapters on the market, but I chose the AutoMeter unit as it seemed to be the most popular.
The AutoMeter unit has 4 wires, i.e, RED = +12v in from the ECU/PCU, Red/Green stripe = +12v out to the coil control packs, Black = ground and Gray = Tach Signal output. Here's a pic of the AutoMeter Tach adapter
To start, you have to fine the purple wire off the ECU/PCU that feeds all 8 Coil Packs. This main Purple wire is fed from the fuse shown in the picture below. This fuse bank is part of the ECU/PCU kit.
After I striped back the wire harness protective tape and seeing the purple wire I cut it to splice in the Red and Red/Green wire from the Tach Adapter. To ensure I cut the correct wire, I put a multi meter to make sure I had +12v from the purple wire, then pulled the fuse to ensure the power was off. After determining I had the correct wire, I installed a Female connector the the ECU/PCU side and a Male connector on the Coil side of the purple wire.
Per the instructions, the red wired from the tack adapter (male connector installed) plugs to the Purple wire from the ECU/PCU side. The red/green wire from the tach adapter (female connector installed) plugs to the purple wire feeding the Coil Packs.
After testing to ensure all worked (including the Dakota Digital tach) I cleaned up the wire runs and wire loomed/taped as appropriate.
I'm now ready to download my Lund tune I received the other day. I'll document that after completion.
Mark
02-14-2025, 12:33 PM
#272
FWIW, I used the - side of the number 8 cylinder coil for the tach signal on the hemi in my 33. Since the Autometer tach that came with the kit only had settings for 2, 4 or 8 cylinders I needed something to convert s 1 cylinder signal to an 8 cylinder signal. I used a Dakota Digital SGI-100BT Universal Speedometer and Tachometer Interface. I programed it for a 1 cylinder input and an 8 cylinder output, works like a charm.
Dave Clement
33 Speedstar
345 Hemi
T5
3 Link
02-15-2025, 07:37 AM
#273
Dgc333
Yes, that's a solution. JUST an FYI for all, Dakota Digital gives cylinder options for 1, 2, 4, 6, 8 and 16 Cylinder (there may be other options I can't recall e.g., 3, and 12 cylinders). I believe the 16 is if you get a .5 (1/2) pulse. I think 16 is also for dual sparkplug per cylinder engines
Mark
02-15-2025, 08:06 AM
#274
mkassab
Mark
The Gen 3 hemi has dual plugs per cylinder. The early engines (pre 2009) had the coils firing on both the power stroke and exhaust stroke. One end of the coil secondary was directly connected to the first plug for the cylinder firing. The other end of the coil secondary was connected to the second plug of the complementary cylinder. The complementary cylinders coil fires its first plug in the exhaust stroke and the other end is connected to the firing cylinders second plug. This is when you need the 16 setting.
The 2009 up hemis one coil fires both plugs at the same time in the power stroke. You used the 8 setting on these engines
