Results 1 to 4 of 4
Thread: Banjo Bolt and Crush Washers assembly. Advice please
    Sep 2021
    Honest Ernie's build# 10314
    Hello everyone, could someone chime in and let me know if this is right (see photo). Putting the banjo bolts onto the calipers. Two crush washers and the banjo bolt, no thread lock or tape used. Mounting and torquing to 29ftlb. Just checking if this looks right to you. I believe this is the way it goes on but putting safety first on this one. Thank you. Honest Ernie
    Correct.
    Sep 2021
    Correct.
    Thank you Jeff. Coming from you is very appreciated. Honest Ernie
    Sep 2015
    Hamersville, Ohio
    29 ft lbs seems like a lot for the banjo bolts but mine look just like yours. I guess I’ll hear about it if that’s too much?
