Thanks Thanks:  20
Likes Likes:  86
Page 1 of 4 123 ... LastLast
Results 1 to 40 of 133
Thread: John's JDM Honda K24A 818R Rebuild
    Syracuse, NY
    Wink John's JDM Honda K24A 818R Rebuild
    This is a continuation of a build thread I started back in 2017 where I documented the initial build of my 818R using a Subaru EZ36 flat 6 engine. To see anything related to the first build of my car with that power-plant please check out the thread listed below. Please post any questions about the old build in that thread.
    John's EZ36R H6 818R Build
    This thread, however, will document the change over from the Subaru H6 engine to the JDM Honda K24A High Performance inline four cylinder engine I have chosen going forward.
    For those who have not seen the car previously, here it is.
    And here is the new engine I will be fitting into the chassis. It is a JDM Honda K24A high performance engine featuring the iVTEC system which has variable timing control on the intake cam PLUS dual lift profiles on both the intake and exhaust cams. Factory rated at 203hp @7000 rpm, this particular engine most likely came out of a 2008-2013 Honda Odyssey Absolute. I know, only the Japanese would put a performance engine in a mini van!
    In any case, subscribe to this new thread to get updates about the Honda install. There will be lots of information about fitting this engine to the 818R as it is not a drop in configuration.
    My goals for this project are:
    • Fit the engine with minimal frame modifications
    • Continue to use the Subaru 6MT transmission from the old build
    • No external body modifications (I don't want to have to repaint any part of the car)
    • Use my existing standalone ECU and other electronics to run the engine
    • Use my existing supercharger and AWIC system to boost performance
    • Make ~300 whp using the completely stock motor
    • Fabricate an oil system (wet or dry) to keep from blowing up this motor
    MK3.1 Roadster completed 2011
  2. Likes Sgt.Gator, Shawn818c, Jetfuel, Rob T, biknman liked this post
    Syracuse, NY
    No Turning Back Now!
    It was really hard emotionally to disassemble basically the entire car. Cutting the wire harness to get it through the bulk head was probably the toughest. I stood frozen for what felt like minutes just holding the wire cutters and thinking about the endless hours spent crimping and trouble shooting all 70+ wires.
    But you have to tear the old down to make room for the new. Here is a pic before and after the firewall removal where I cut out the entire center "A" section of supports so I could mock up the engine placement.
    After shedding a few tears I got down to the job at hand. So...is this thing really going to fit?
    Here is a pic with the engine in the straight up vertical position, followed by 2 of the engine at a 15o tilt. The stock motor sits at a 15o tilt from the factory. The transmission adapter plate is available at both 0o & 15o angles.
    Still not 100% sure of which way I'll go, but I'm leaning towards the 15o tilt for a couple of reasons.
    • If I go wet sump, the stock pan already has a 15o angled bottom.
    • It gives me a slightly lower overall vertical engine height when tilted.
    • That's how the factory intend it and I don't really see any downside to it.
  4. Thanks Jetfuel, Rob T thanked for this post
    Likes Kurk818, Bob_n_Cincy, Sgt.Gator, weendoggy liked this post
  5. #3
    Syracuse, NY
    Ordered the transmission adapter plate from Kennedy Engineering. Went with the 15o engine tilt. They take 5-6 weeks to get. Updates will be slow until it arrives.
  6. #4
    Near Denver Colorado
    Thank you John for the updates and the work you did on the ez36. I still have a ez36 and controller in the garage. I may get it installed this winter.
    Larry
  7. Likes Hobby Racer liked this post
  8. #5
    Wow, Kennedy has been around for a while. They built and adaptor for me in 1995. I was building an electric Plymouth Voyager Minivan.
    https://1drv.ms/u/s!AgduxxAs3q-xjDbj...K3DFe?e=q5B9fT
  9. #6
    Syracuse, NY
    I picked Kennedy over the one other vendor that does an adapter kit from Australia because Kennedy is US based, less expensive and should have a faster turnaround.
  10. #7
    Syracuse, NY
    Fitting a Larger Throttle Body
    While waiting for my adapter plate to arrive I'm trying to find smaller side projects to stay engaged with this rebuild/swap. I pulled the factory intake and throttle body from the Honda motor for cleaning and noticed how small the throttle body opening is, 62mm. I thought to myself, I have a perfectly good larger throttle body that already mates up to the intercooler tubing I have from the EZ36 motor. Checking the mounting pattern reveled that the two are not that different.
    So when you have a milling machine and you are bored, you modify stuff
    I offset drilled the Honda hole pattern onto the Subaru throttle body plate and it fits very nicely.
    The only hiccup is this weird notch Honda cut in the bottom of the intake manifold. It does not seem to serve a purpose. Even the Honda throttle body just caps it off. If I am to use the larger throttle body I will need to make an adapter plate to cover the notch or weld in a plug and re-machine the mating surface.
  11. #8
    Senior Member Rob T's Avatar
    Woodruff, SC
    This work must make for some interesting fixturing. I'd love to see some pictures of that when you do it. I find I can always learn a lot from others.
  12. #9
    Syracuse, NY
    It did! I should have taken some pictures but I didn't. I'll try to remember to next time.
  13. #10
    Jul 2017
    Very nice! Good to see this happening more often. After years of work and family stuff halting work mine is finally back apart and the frame ready to be powder coated. I am also running a megasquirt and a dbwx2. That weird dip in the intake manifold is only present on the 04-05 motors. In the usdm 06-08 manifold that is gone and the runners are a little fatter.
  14. #11
    Dec 2021
    I ran a K24A3 with a rotrex supercharger... needed the 50 degree inlet cam and pulley from the type R, 1000cc injectors and AEM computer. Made 406 hp at the rear wheels. Stock bottom end and pistons.
    Good choice!
  15. #12
    Syracuse, NY
    Quote Originally Posted by 7ish View Post
    Good choice!
    Wow! If you don't mind me asking, what model Rotrex supercharger and what pulley size did you use? Also, how much boost did it make and at what RPM?
  16. #13
    Jul 2017
    Good choice!
    That would be wild in an 818. The 50 deg vct also comes in the base rsx k20a3 and the k20a2 rsx type s. Though they claim in vtec on the early k24a a2 engines you cannot run that much cam advance due to piston to valve clearance. Better to cut the 25deg cam gear to run up near 40 deg. The stock k24 in an 818r with its weight is going to be fairly quick. I have an 818c and am planning to go turbo after I run it na and that may not be necessary.
  17. #14
    Jul 2022
    love this project and good luck with the progress
  18. #15
    Dec 2021
    Rotrex was a C30-94, running up to 15psi. K20 crank pulley, I can't remember the size of the supercharger pulley, but it was set to give max rotrex rpm at engine redline.
    Inlet cam advance limited to 45 degrees. Here's a link to the car I put it in, along with the dyno graph.
    https://www.trademe.co.nz/a/motors/s...8?bof=xYgmL9B1
    I wanted plenty of low end boost but not too much at high rpm, so I used a wastegate on the inlet pipe to limit high rpm boost. (Visible in the pictures).
  19. Thanks Hobby Racer thanked for this post
  20. #16
    Syracuse, NY
    Very cool, thanks!
    I may be in a similar situation since my supercharger is a bit over-sized for the stock K24. I'm using the Rotrex C38-91 from my previous engine which was a 3.2 liter 6 cylinder. I either have to run a huge supercharger pulley and a small crank pulley and lose my bottom end or do what you did and run a wastegate on the inlet.
  21. #17
    Syracuse, NY
    Custom Bracket for the Supercharger
    Here is what I came up with to mount the Supercharger low on the K24 engine. I still need to remove some excess material in the area marked in pencil. But I have not yet decided how much and what shape(s) to use.
    My original design, shown in the next picture just above the new design, mounted the supercharger higher up and to the right of the alternator. That made for a really long belt span between the crank pulley and the supercharger pulley. I did not like that so I tucked it down low about where the factory AC compressor goes.
    I started with a 3/8" thick plate of 6061-T6 aluminum I had left over from the last bracket I made. The rotary table made it easy to get the large radius hole and curves just right. I find it very helpful to glue a full scale drawing of the part I'm making to the material before machining. This way it is easy to see if I'm doing the right thing with the dials and the reference dimensions are right in front of you at all times.
    IMG_20221117_104759112.jpg IMG_20221117_110521688.jpg IMG_20221117_112726097.jpg
    It's always fun to play in the garage with my big boy toys.
  22. Likes Rob T liked this post
  23. #18
    Syracuse, NY
    Maybe something simple. Triangle and circle?
  24. #19
    Dec 2021
    I used an electric water pump... made for easier install...
  25. Likes Hobby Racer liked this post
  26. #20
    Syracuse, NY
    Transmission Adapter Kit Final Arrived!
    After about 8 weeks my transmission adapter kit has finally arrived from Kennedy Engineering. The fit and finish is beautiful. The plate is 28mm thick aluminum and weighs in at 6 lbs 4.4 oz. The custom made flywheel is machined out of a 28mm thick steel plate. and weighs 21 lbs. 9.4 oz. Heavy, I know but what you going to do.
    They even include all new hardware, including ARP flywheel bolts. Fasteners weigh in at 2 lbs 4.6 oz.
    Total kit weight is 30 lbs 2.4 oz.
    Here is the back side of the flywheel.
  27. Likes Kurk818, Rob T, Bob_n_Cincy, J R Jones, DSR-3 liked this post
  28. #21
    Woodruff, SC
    Santa came early this year, and it's no lump of coal....
  29. #22
    USA
    That Kennedy kit looks great! It's nice that they provided all the hardware. Very professional. Subarugears could learn something from them.
  30. #23
    Yes, I love Technology
    aquillen's Avatar
    NW Indiana
    John, that belt tensioner shown on your front adapter plate - what is the part # info on that if you have it? I keep having to adjust my belt about 6 months apart - no tensioner. Looking for the smallest I can find and looks like you may be showing me what to try... tx. Art
  31. #24
    Syracuse, NY
    Quote Originally Posted by aquillen View Post
    That's not my engine photo . You might want to ask 7ish
  32. #25
    aquillen's Avatar
    NW Indiana
    So I see looking back - thanks
  33. #26
    Syracuse, NY
    Xmas shopping done so I get to work on the car!
    Fitting a K24 into the 818R and keeping it below the rear deck lid is not for the faint of heart! Combine the extra length of an inline 4 cylinder with the 1" thick transmission adapter AND a 6 speed, which is larger in every dimension compared to a 5 speed, is like trying stuff 20lbs of crap into a 10lb bag.
    With significant frame modifications, it's going to fit with maybe a 1/4" to spare in almost every direction.
    IMG_20221224_122730503.jpg IMG_20221224_122743406.jpg IMG_20221224_122807013.jpg IMG_20221224_122815987.jpg IMG_20221224_122722336.jpg IMG_20221224_122707975.jpg
    I'm going to have to lower the entire drivetrain ~5 inches. This will put the engine in between the upper and lower square frame tubes that the aluminum firewall bolts to. The motor belt and pulleys will protrude into the area that used to have the "A" shape firewall supports that I have cut out already. The oil pan will sit above the floor pan by about 1/4" and the valve cover will be even with the top of the 1.5" square tube that the round roll bars connect to. About a 1/4" gap will be present between the front of the engine valve cover and the back side of 1.5" square tube.
    The rear section of the frame below the transmission will have to be cut out entirely and a new lowered section will need to be fabricated. I will have to cut my rear diffuser into a right and left section now. The transmission will hang below the frame significantly. I will most likely make a sturdy skid plate to avoid damaging the transmission if I have an off track event.
  34. Likes Rob T liked this post
  35. #27
    Dec 2021
    Belt tensioner is : Gates 38382 Belt Tensioner
    Bought via Amazon. Not sure what the original car is, sorry.
  36. Thanks aquillen thanked for this post
  37. #28
    aquillen's Avatar
    NW Indiana
    You recall seeing a thread a couple years back showing how the rear frame area for the transmission support developed cracks? I'd say triangulate the rear support all the way back during your design of the necessary new support.
  38. Thanks Hobby Racer thanked for this post
  39. #29
    Syracuse, NY
    I don't recall that thread. I do plan to triangulate as much as I can. I'll post pics along the way so everyone can comment on my design choices.
  40. #30
    Syracuse, NY
    Let the cutting begin!
    Time to make room for the transmission to be lowered. I cut out the entire center section under the transmission. It's now a hollow rectangle. I will be keeping the rear most 1x1 square tube and the middle 1.5x1.5 square tube. For now they are keeping the rear frame geometry in place.
    1. pic, unaltered transmission section.
    2. pic, transmission section cut out.
    3. pic, clean view without the center section.
    Here you can see where I'm going to carve out some of the rear transmission cover to allow the tail to sink below the rear 1x1 square tube frame piece. I plan to keep that piece as it secures my rear bumper and diffusor to the car. After cutting along the RED lines I will tig weld in some thin plate aluminum to seal up the back of the transmission.
  41. #31
    Falmouth, MA
    Just a thought, why not just jog the steel tube around the rear of the transmission case so you don't have to cut the case and fabricate a cover that must be perfectly sealed so fluid doesn't leak out? Maybe even jog under the tranny.
  42. #32
    Syracuse, NY
    Quote Originally Posted by cob427sc View Post
    The rear bumper sits tight to the back of the bar now and bolts to it from the bottom. I don't want to go around as that would push the bar through the rear bumper.
    Going under is doable but it would require bodywork to reshape the bottom of the rear bumper and relocate it's mounting points. If I cut the transmission case I can fit it without any body work or modification to the rear bumper.
    I've already cut up the transmission cover once before, you can see the weld beads in the last picture. It's not that difficult.
    I guess I'll think on that a bit more before I cut anything.
  43. #33
    In my original 818 cooling design I had a rear mounted Radiator. In doing so i needed to shorten the transmission by 3 inches. I accomplished this by going through the side of the transmission and cutting of the shift shaft out the back. I don't know itf this is possible with the MT6 transmission.
    Better explianed by this video:
    This wasn't my final design, but you get the idea.
  44. #34
    Syracuse, NY
    I remember that post, very interesting but it's not possible with twin shift shaft design of the 6MT.
  45. #35
    Syracuse, NY
    In my last build I restored/rebuilt a Bridgeport milling machine that I love. You can see it in the background of this picture. In this build I just finished rebuilding/restoring my first metal lathe, a 1942 Monarch 10EE toolroom lathe. This will definately come in handy with the 818R! I already made a bushing I needed to reloacate the idler pulley on the K24 engine.
    Next post will be car related I promise
  46. Likes Bob_n_Cincy, Rob T liked this post
  47. #36
    Woodruff, SC
    Hobby: Both the machines look beautiful. I went the PM Matthews route on a PM10/30 lathe and a table top mill (PM727). I have had a blast building tools like a die holder for the lathe and a spring loaded tap follower that works on the lathe and the mill. I think you told me that once you have these tools, you look for reasons to use them. My brother is a wood worker and thinks 1/16" is close enough. I tell him that 1/16" is 62.5 thousandths, and not even in the ballpark. Congratulations.
  48. Likes Hobby Racer liked this post
  49. #37
    Syracuse, NY
    Rear Transmission Cover Slim Down
    Now that some of my side projects are coming to an end I can get back to the car. Before I can finalize the engine / trans position in the engine bay I need to know all my clearances. This meant I needed to finish the transmission rear cover slim down project. To maximize the room I needed to make the rear cover as slim as possible so I cut out every possible inch and now if fits without having to cut the rear most frame bar which holds up my bumper and rear diffuser. As you can see, the transmission now sinks nicely below the rear frame sections and has decent clearance while preserving the rear frame bar.
    Making the cutout was quite the challenge. First I had to cut the majority of material out with a good old fashioned hacksaw as the cover would not fit in my metal band saw. Next it was over to the mill for cleanup to final dimension.
    I then bent up a piece of sheet aluminum to fit and trimmed all the edges to match the odd shape hole left in the cover. The hardest task was welding up the plate to the casting. Welding oily old cast aluminum is a very frustrating. It took many rounds of welding, grinding out the crappy contaminated welds and re-welding to get it done so it didn't leak.
    The finished product is still some on my worst welding, but it's sealed up and doesn't leak so I'm moving on.
  50. Likes Rob T liked this post
  51. #38
    Mar 2021
    SE WI Kettle Moraine
    Die castings are hard to weld. Oil not withstanding die cast have impurities and porosity.
    Sand castings and matched plate castings are much easier to weld. Different alloys.
    I have seen the low temperature weld rods at the EAA that work with propane or Mapp gas but I never used them. They claim they work on die cast and pot metal which has similarities to die cast aluminum.
    jim
  52. #39
    Syracuse, NY
    Accessory Drive System Done
    I finally got the serpentine drive belt system worked out and completed. I finished welding the supercharger mounting bracket and fabricated a needed idler pulley at the top so I could run the original accessories and keep the factory belt tensioner. Most people get rid of the water pump, pump housing, alternator and belt tensioner when they swap in a JDM K24. This is because they are different from the versions that come on USDM K24's. I figured I would save some time and money and use the JDM stuff that came with the engine. If something fails down the road I still have a complete spare engine to pull parts from.
    I modified the factory front engine support bracket to use as the base for my upper idler pulley. I had to support the pulley from the opposite side as all the other pulleys since there was not enough clearance on the back side closest to the block. I experimented with multiple pulley positions and settled on the current spot.
    IMG_20230215_161206432.jpg IMG_20230216_134957761.jpg IMG_20230216_134950773.jpg IMG_20230216_134817725.jpg IMG_20230216_134801505.jpg
    Now I am just waiting for the new belt I ordered to arrive. I hope it is a perfect fit. I also added a smaller crank pulley from a JDM K20 Type-R motor. it's lighter and smaller and drives the accessories slower, generating less parasitic drag.
  53. Likes Rob T, 7ish liked this post
  54. #40
    Syracuse, NY
    I ordered a cheap Chinese knock-off of a good Honda intake manifold
    I was actually pleasantly surprised by the casting quality. All the machined edges need deburring , but are smooth and flat.
    I need to modify it to accept a GM intake air temperature sensor so I had to find a way to fixture it in my mill. Here is an example were you need to get creative. The surface I need to drill and tap is under the level in the pictures. It is not flat, nor aligned with any machined edges. So I worked off the throttle body mounting plane as its machined flat and true and used wooden blocks and wedges under the manifold to get the area I'm working on level in the Y axis. The X axis was close enough and didn't need shimming.
    When that's all done I will machine the adapter plate needed to mate the Honda Intake to the Subaru throttle body. I designed it in CAD to ensure everything fit well before cutting any metal. Then I'll finish it up by port matching it to the larger Subaru throttle body I'm using.
  55. Likes Mark Eaton liked this post
