Where do you route rear harness out of footbox?
Before I turn these beautiful panels into swiss cheese, I'm checking in here to see where you route the rear harness out of footbox and down the tranny tunnel. I'm thinking the route highlighted in yellow will stay out of the way of the Coyote and power wiring. Planning to layout the Coyote PDB harness similar to EdwardB's well documented and clean layout. no need to reinvent the wheel..
The typical routing of the harnesses is through the firewall. You need two or three holes per the harness instructions. I used three.
The way you plan to do it is exactly how I did mine. You can see it in this photo.
MkIV Roadster build: Gen 2 Coyote, IRS, TKO600. Ordered 10/24/18. Delivered 1/29/19. Engine installed 8/8/21. First start 9/12/21. First go-kart 9/17/21. Off to paint 4/11/22. Back from paint 12/30/22.
Build thread here.
Moniz thanked for this post
Thanks both!
JohnK, how did you mount your 250A fuze box to the panel? Can't tell if those are bolt heads or not. I'm trying to keep the cabin side of that panel as smooth as possible
I mounted it on a small bracket that I fabricated:
Build thread here.
Post Thanks / Like - 2 Thanks, 1 Likes
