Misc parts called out on FF Parts list & options sheet?
As many of you know, I have a build tread going for my '35 truck (link in my signature below). I'm in my planning stage and buying what I can before the FF kit is delivered.
I'll have a series of these "Specific Question" treads so to keep topics separate.
This Thread is regarding the Gen 3 Coyote.... specifically, FF's Parts list & Options sheet (see pic below). The four part I'm still unsure of are all circled in blue pen with a blue question mark.
- Coyote Oil Pan - with this listed, I'm assuming the OEM oil pan mush be changed? I've seen in some pictures and the FF install manual, the Coyote has a Moroso rear sump oil pan.... what part number is the Moroso if needed?
- Coyote Oil pan Pick-up... part number?
- Oil Pan Sensor plug... part number?
- Starter Brand and part number?
I'm trying to avoid buying duplicate parts.
And YES, I've asked several folks from FF via email and have yet to hear from them. So I thought I'd reach out to those with real world experience.
Thanks in advance,
Mark
Quoted from a post I found from Paul "edwardb": Moroso 20570 is the pan. Two different pick-ups depending on Gen 2 or Gen 3.
I also found this pickup, but will defer to the folks who have experience with the installation of the Gen3 Coyote to confirm if it is the correct part.
https://www.moroso.com/oil-pump-pick...-kit-car24577/
I'm not familiar with buying an engine/trans from Factory Five. But are you certain they haven't already swapped the oil pan? For the Coyote, it means the parts listed: Pan, pickup, plug, and for the Gen 3 also a new gasket/windage tray. Approaching $1K for all that stuff. I'd sure check they aren't already swapping it out.
Starter is hopefully the standard Motorcraft Coyote starter. It's a decent piece. For the Hot Rod and Truck, the standard Motorcraft alternator doesn't fit. They use a modified Honda piece that's installed in a different location and orientation with brackets they've designed. Check the Hot Rod Gen 3 Coyote instructions: https://www.factoryfive.com/wp-conte...Rod-rev-1C.pdf.
Build Thread and
Video.
Build Thread and
Video
Build Thread. Sold 11/9/2023.
Originally Posted by
edwardb
Hi Paul, Sorry I wasn't clearer. I'm NOT buying the Engine package from FF, but a crate Gen 3 coyote from a 3rd party for my '35 truck. It's a standard Ford Perf crate engine. However, when "reviewing" FF's list, I saw the items I circled that I need more info on.... Therefore, why I was asking for brand and part numbers for the 4 items. I'm all set on the Honda Alternator and will just need FF's custom bracket.
Thanks Mark
mkassab
Thanks Mark
OK. Now I get it.
Coyote Oil Pan: Moroso 20570
Coyote Oil pan Pick-up: Moroso 24577 (Gen 3 specific)
Oil Pan Sensor plug: Moroso 22738
You'll also need a BR3Z-6710-A Oil pan gasket/windage tray. Gen 3 Coyote has a composite oil pan with integral gasket.
Starter Brand and part number: Ford Performance 5.0 Starter Kit M-11000-C50. There are other aftermarket brands I believe. But this is the one I've used for my Coyote builds.
Hope that helps.
Build Thread and
Video.
Build Thread and
Video
I have a Honda alternator and bracket for sale if your interested. I have the headers too. removed from a Hotrod project that went through an engine swap before it was ever started.
michael everson
PM sent
